hi... i need bios bin for motherboard 6050a2345301-mb-a02....Thanks...
hp touchsmart tm2-2150es
Every donation made will go towards server fees and maintenance costs.Tags: None -
Re: hp touchsmart tm2-2150es
Can you post your bios backup . -
orig.old biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Try this one, and give feedback .Attached Filesif you find these attachements useful please consider making a small donation to the site
with the given bios does not go through the "starting windows" and the cooler is spinning at maximum speed ... ec orig 512k ... maybe there is something wrong here the sent has 64k ..Attached Filesif you find these attachements useful please consider making a small donation to the site
hdd ok...win ok...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Heres another bios,its fixed now, hopefully .Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello! the initial problems were: the windows opened after 10 minutes after starting, after which the touchpad and usb did not work. when the power supply was inserted into the laptop socket, it started without pressing the start button, the cooler was spinning at full speed ... after the changes made in bios by SMDFlea, the laptop does not go into windows but stays in "start windows" and starts from the start button . the tensions are ok, hdd ok, windows ok.Original ec 512kb, not 64kb ... I sent to position 5 (# 5) original ec 512kb ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Heres the new 512kb EC .The original EC may be 512kb but it only has 64kb of code,you can check it with a hex editor. The 64kb EC was cut from the official hp bios.Attached Filesif you find these attachements useful please consider making a small donation to the site
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by DiddiAbRecently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...-
I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
The motherboard of my ASUS... - Loading...
