HP 11-k118tu bios dump
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hello Guys. Its been awhile. Does anybody here have bios dump for this laptop HP11-k118tu also known as HP360?
    Sometimes laptop turns on with no display. Need to repeat on and off process to boot windows 10. I'll try bios first, because its the easiest.
    I went to hp website and downloaded bios but its bigger than stock rom. I'll upload bios file here maybe someone can fix it coz I don't know how. Thanks to all!
    PS. stock means it came from chip
    website means it came from hp website
    • 20918
    Re: HP 11-k118tu bios dump
    Try this one
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Ok sir, I'll try this one and update you asap. Thanks very much!
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        Tried new bios but problem still the same. Maybe bios is not the issue coz every components is built in, like soldered to board. The processor and memory is fused to board.
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          try to find more clues and symptoms of the problem. how is it with the AC adaptor or the battery only?
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            Today, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            07-28-2025, 07:11 AM
