HP 11-k118tu bios dump
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Hello Guys. Its been awhile. Does anybody here have bios dump for this laptop HP11-k118tu also known as HP360?
    Sometimes laptop turns on with no display. Need to repeat on and off process to boot windows 10. I'll try bios first, because its the easiest.
    I went to hp website and downloaded bios but its bigger than stock rom. I'll upload bios file here maybe someone can fix it coz I don't know how. Thanks to all!
    PS. stock means it came from chip
    website means it came from hp website
    • 20653
    Re: HP 11-k118tu bios dump
    Try this one
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Ok sir, I'll try this one and update you asap. Thanks very much!
      • lezsimply
        The Wanderer
        • 645
        • Philippines
        Tried new bios but problem still the same. Maybe bios is not the issue coz every components is built in, like soldered to board. The processor and memory is fused to board.
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          try to find more clues and symptoms of the problem. how is it with the AC adaptor or the battery only?
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
