Asus x556uv
  • Hombre
    • Jul 2013
    • 231
    • Croatia
    #61
    Re: Asus x556uv
    Tried both bin files, no joy. Than I tried to flash the known working backup to my old BIOS IC and it didn't work. So most probably it's IC that is damaged, although CH341 flasher does not report any errors, but who knows. I will get a new 25Q64fvsig and try it again, in mean time laptop will work with URK bios
    Thank you guys!
    • Nurshad
      • Oct 2019
      • 75
      • bangladesh
      #62
      Re: Asus x556uv
      Asus X556UV Core i5 7gen power on black screen no display help me
      • peste
        • Dec 2016
        • 12852
        • ROMANIA
        #63
        Re: Asus x556uv
        Originally posted by nurshad
        asus x556uv core i5 7gen power on black screen no display help me
        try..
        • dqtech
          Badcaps
          • Jul 2018
          • 630
          • N/A
          #64
          Re: Asus x556uv
          thanks
          • razadom
            • Apr 2015
            • 100
            • Madagascar
            #65
            Re: Asus x556uv
            Hi all
            I have problem with asus vivobook core i7 with nvidia GPU mb ref x556uv rev 3.1
            the white sticker and dump were attached.
            there is no display. i measured 0V on VCCGT coil. All voltage is ok.
            I've flashed with bin at post #7 but the same result.
            Somebody can clean ME or give me a good dump
              • 20976
              Re: Asus x556uv
              Originally posted by razadom
              Hi all
              Post the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570
              The picture is blurry does it say X556UQ on the barcode sticker
              • razadom
                • Apr 2015
                • 100
                • Madagascar
                #67
                Hi all
                this is the serial number of my asus laptop
                FL5900UQ6500-154BSCA2X10
                Some one can share good bin or clean me
                thanks
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11787
                  #68
                  Hi all
                  thanks
                  X556UQ
                  • dukax
                    • Jun 2015
                    • 6
                    • serbia
                    #69
                    After flashing I don't have the serial number in the bios, touchpad it doesn't work and the fan runs at maximum. Any idea. Thanks
                    • Vesko356
                      Vesko356 commented
                      Editing a comment
                      You MUST:
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      • Name your thread with make, full model numbers and request
                      • Provide a BIOS/EC dump if possible
                      • Attach files directly to your post instead of linking to external websites
                      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                  • Maicon Provin
                    • Jan 2025
                    • 12
                    • Brasil
                    #70
                    Olá, você pode remover a senha do bios?
                    NOTEBOOK ASUS X556UQ
                    CÓDIGO DA PLACA X556UV 3.1
                    CPU I5-7th
                    NVIDIA 940MX GPU
                    serial number: H5N0CV09P92420H
                    Veja o arquivo em anexo
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      #71
                      Originally posted by Maicon Provin
                      Hi, can you remove the bios password?
                      ASUS X556UV 3.1
                      CPU I5-7th
                      NVIDIA 940MX GPU
                      See attached file
                      You must write the serial number before demanding any support
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11787
                        #72
                        CPU I5-7th
                        NVIDIA 940MX GPU
                        Password : Admin12
                        • Maicon Provin
                          • Jan 2025
                          • 12
                          • Brasil
                          #73
                          Originally posted by hoaca388
                          Password : Admin12
                          The password worked in a moment then it blocked again but the password changed automatically if you can remove the password and send me the file I would be grateful.​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11787
                            #74
                            Here
                            • Maicon Provin
                              • Jan 2025
                              • 12
                              • Brasil
                              #75
                              Here
                              This bios works perfectly without the password. thanks
                              • kcp0085
                                Request BIOS dump for ASUS FA617NS-A16.R77600
                                by kcp0085
                                Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                Specs:
                                - ASUS TUF FA617NS-A16
                                - CPU: AMD Ryzen 7
                                - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                Thanks in advance!​
                                05-02-2025, 12:52 AM
                              • Tamo Neko
                                Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                by Tamo Neko
                                I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                What Happened:
                                I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                What I Need:
                                • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                02-12-2025, 11:29 PM
                              • Anchar777
                                ASUS P1412CE need BIOS DUMP
                                by Anchar777
                                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                06-26-2025, 03:39 AM
                                ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                09-07-2024, 02:50 AM
                                ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
