Asus x556uv
    • 21388
    Re: Asus X556UV bios repair
    Originally posted by salawayon
    thanks but i already tried that file, it's working but there's a problem with NVIDIA GPU. can't install drivers. maybe the original repaired BIOS file could fix the NVIDIA drivers.
    Post a picture of the white barcode sticker on the motherboard,it should be near the soldered ram
    https://www.badcaps.net/forum/showthread.php?t=96604
    • c.daniel
      • Mar 2017
      • 108
      • Romania
      #42
      Re: asus
      Originally posted by ElecPCTech
      BIOS is confirmed and working.
      Asus X556UV Rev: 3.1
      CPU: i7-7500
      GPU: Nvidia N16V-GMR1
      Hello; thankyou very much, bios is working perfect.
      Asus X556U with mb X556UV_MB
      cpu i7-7500u
      gpu intel hd 620 and nvidia 940mx
      Initial behaviour is that laptop was power on, white led light, but no picture; i think problem appears because mb has no bios battery, and main battery is dead; modern problems....
      • jamshad
        • Mar 2022
        • 3
        • saudiarabia
        #43
        Re:Asus X556UV Rev: 3.1 I7 7th bios need
        hello, I tested all the .bin but not worked on my board.
        Asus X556UV Rev: 3.1 Rev: 3.1
        CPU: i7-7500
        GPU: Nvidia 930mx
        Problem is my laptop was power on, white led light, but no picture.battery also dead
        PLZ HELP ME
        • peste
          • Dec 2016
          • 13132
          • ROMANIA
          #44
          Re: Asus X556UV Rev: 3.1 I7 7th bios need
          CPU: i7-7500
          GPU: Nvidia 930mx
          PLZ HELP ME
          try..
          • jamshad
            • Mar 2022
            • 3
            • saudiarabia
            #45
            Not worked
            • hoaca388
              Badcaps
              • Jan 2022
              • 12043
              #46
              Not worked
              Try
              • jamshad
                • Mar 2022
                • 3
                • saudiarabia
                #47
                Originally posted by hoaca388
                Try
                doesn't work
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12043
                  #48
                  doesn't work
                  Find hardware issues problem.
                  • kingkong computers
                    • Sep 2018
                    • 208
                    • pakistan
                    #49
                    Re: Asus x556uv
                    need 7th gen bios but without dedicated graphics
                    asus x556uv-mb rev 3.1
                      • Sep 2018
                      • 208
                      • pakistan
                      #50
                      Re: Asus x556uv
                      plz clear my bios no display
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12043
                        #51
                        Re: Asus x556uv
                        Find an image of the QR code or stickers on your motherboard and upload it here.
                        • Mazorca
                          • Jan 2017
                          • 463
                          Re: Asus x556uv
                          You actually have an Asus X556UAK. Try this one:
                          • korg
                            • Jan 2015
                            • Sri Lanka
                            #53
                            Re: asus
                            CPU: i7-7500
                            Working Thanks
                            • Hombre
                              • Jul 2013
                              • 231
                              • Croatia
                              #54
                              Re: Asus x556uv
                              Hi
                              I have a really strange problem with this laptop.
                              So the model number is X556UQ, with the i7, integrated intel graphic and Nvidia 940MX.
                              When i first got he laptop i saw that somebody ripped pads in the BIOS area, so manage to fix that and took the backup of the BIOS. Although all voltages were fine it wouldn't boot, so tried all possible bioses that i found here and it wouldn't boot with any of those.
                              So i got another motherboard that is not working to try to get it running, unfortunately the PCH on that one is shorted.
                              So, finally i took a BIOS chip from that one and installed it on original motherboard and the laptop started!
                              But, now the Laptop thinks that the model number is X556URK (assume that damaged motherboard was from that model). Issue is that the 940MX is recognized in windows, but windows are reporting error code 43, which is some graphic issue error.
                              In the bios card is recognized like 930MX, but there is no possibility to activate it, see photos.
                              So only BIOS that starts X556UQ laptop is with the bios chip from X556URK, all others bring current consumption to 200mA, but the laptop is not starting.
                              Could be that my CH341A is not ok, but is not reporting any errors, or even the BIOS chip.
                              I don't have a spare one except the one that is working but i don't want to mess with that one because if something goes wrong with it i am screwed
                              Here is a backup from working BIOS, i would like that somebody gives me an explanation why is this the only one that is able to start the laptop, but with some nvidia graphic card issue.
                              PCB of the board is X556UV ver 3.1
                              Thanks!!!
                              • peste
                                • Dec 2016
                                • 13132
                                • ROMANIA
                                #55
                                Re: Asus x556uv
                                Originally posted by Hombre
                                Hi
                                Thanks!!!
                                post clear pictures of the white stickers from the ram memory area or a square with white paint with a QR code...from the motherboard...
                                • Hombre
                                  • Jul 2013
                                  • 231
                                  • Croatia
                                  #56
                                  Re: Asus x556uv
                                  Unfortunately the sticker is not on the board anymore, it felt, and there is no QR code on the board either except for the one on the cooler but i assume that is the coolers part number.
                                  The URK board has it's sticker still but i assume you don't need that one.
                                  I took a photo from the sticker with the model number of the laptop, maybe that can help.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12043
                                    #57
                                    Re: Asus x556uv
                                    Your correct model's X556URK
                                    • peste
                                      • Dec 2016
                                      • 13132
                                      • ROMANIA
                                      #58
                                      Re: Asus x556uv
                                      try this...if it doesn't work try post #44
                                      • Hombre
                                        • Jul 2013
                                        • 231
                                        • Croatia
                                        #59
                                        Re: Asus x556uv
                                        The second photo is from the board that has the PCH shorted, the bottom sticker says X556UQ-XX453T. Just to clear the confusion. First photo is the working board but it works only with URK bios.
                                        Only thing is that i don’t get it why the 940MX graphic is not working, although recognized in Windows as 940MX and in Bios as 930MX.
                                        • hardware1
                                          • Sep 2021
                                          • 2943
                                          • N/A
                                          #60
                                          Re: Asus x556uv
                                          Only thing is that i don't get it why the 940MX graphic is not working, although recognized in Windows as 940MX and in Bios as 930MX.
                                          Do you have the original backup? You mentioned in post #54 that you took a backup after fixes the ripped pads, If yes upload it.
                                          all donations are welcome,
                                          • kodox
                                            Asus ExpertBook B1400CB Bios Dump Needed
                                            by kodox
                                            need original bios dump, original bios has flashed by other technician before me.
                                            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                            unit info:
                                            Model: Asus ExpertBook B1400CBA-0711A1235U
                                            S/N: R6NXNZ006657238
                                            CN: 7F6F
                                            Mainboard Code: B1500CBA R2.1...
                                            08-16-2025, 12:20 PM
                                          • kcp0085
                                            Request BIOS dump for ASUS FA617NS-A16.R77600
                                            by kcp0085
                                            Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                            I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                            Specs:
                                            - ASUS TUF FA617NS-A16
                                            - CPU: AMD Ryzen 7
                                            - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                            If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                            Thanks in advance!​
                                            05-02-2025, 12:52 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • Anchar777
                                            ASUS P1412CE need BIOS DUMP
                                            by Anchar777
                                            Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                            06-26-2025, 03:39 AM
                                            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                            09-07-2024, 02:50 AM
