wsnu main board rev 2.1 bios dump file
  • mbsurfer2018
    • Jun 2018
    • 18
    • Puerto Rico
    Hello!
    I need a bios dump file for a bricked HP Pavilion dv4-5113cl notebook Wsnu main board rev 2.1. The file is 4 MB.
    So far all the sites that I search it ask for a paid membership to download.
    I made a mistake in my previous thread and entered the wrong notebook model.
    Thank you very much and good day.
    • 21048
    Re: wsnu main board rev 2.1 bios dump file
    Try the one at post #6
    https://www.badcaps.net/forum/showth...ght=dv4-5113cl
    • mbsurfer2018
      • Jun 2018
      • 18
      • Puerto Rico
      Thank you SMDFlea
      Here is my Winbond read
        • 21048
        The bios from the mediafire link is the correct bios for your laptop. You will need to enter your DMI info after flashing that bios. Use this guide to make a bootable USB flash drive,and enter your DMI info - (Method 2 : Burn the serial-number into the motherboard (Rufus & DMIFIT)
        https://superuser.com/questions/6880...n-my-hp-laptop
        • mbsurfer2018
          • Jun 2018
          • 18
          • Puerto Rico
          Oh thank you
          I forgot to do that but the machine booted anyway. The situation now is that I made a reset because the OS seemed corrupted, it was a Win 10 free upgrade from Win 7 Home premium, I wanted Win 7 back but I lost the OS.
          I will try to install Ubuntu and will do DMI info.
          Thank you very much.
          • arcsolcomputer
            • Feb 2020
            • ETHIOPIA
            i need bios bin for dvd-5213 ci wsnu main board rev:2.1
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
