NP270E5J - LAMPARD-15HSW REV 1.0 BIOS need
  • Mcfalsi
    • Apr 2015
    • 193
    • Türkey
    Hi please bios dump
    • 22286
    Re: NP270E5J - LAMPARD-15HSW REV 1.0 BIOS need
    Try the one at post #3 , use the forum search !
    https://www.badcaps.net/forum/showthread.php?t=41448
    • Mcfalsi
      • Apr 2015
      • 193
      • Türkey
      1.I used the forum call but could not find it
      dont work my main borad model LAMPARD-15HSW REV 1
      • Mcfalsi
        • Apr 2015
        • 193
        • Türkey
        please help
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Originally posted by Mcfalsi
          please help
          Post your dump here. I'll try to help
          • Mcfalsi
            • Apr 2015
            • 193
            • Türkey
            notworking dump
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              notworking dump
              try this...
              goodluck and please confirm..
              • Mcfalsi
                • Apr 2015
                • 193
                • Türkey
                Originally posted by rioreno
                try this...
                I got a chance to try it, unfortunately did not work
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Try this bios. I have tried merging your dump with a known good dump. Post result
                  • Mcfalsi
                    • Apr 2015
                    • 193
                    • Türkey
                    It did not work soryy
                      • 22286
                      Your bios dump is exactly the same as the one posted here at post #5 https://www.badcaps.net/forum/showth...light=np270e5j
                      Try this bios with clean ME .
                      • daniel92
                        • Jan 2015
                        • 12
                        • kenya
                        KINDLY HELP,TRIED THE OTHERS BUT DIDN'T WORK
                        • bios123
                          • May 2017
                          • 5
                          • turkey
                          work bios
                          • bios123
                            • May 2017
                            • 5
                            • turkey
                            bios
                            • ratim
                              • Apr 2020
                              • Brazil
                              Originally posted by bios123
                              bios
                              Worked perfectly on a NP270E5J. Thank you very much!!
                              • cuslaw
                                • Aug 2016
                                • 3
                                • TURKEY
                                bios
                                P01RCK for worked thanks!!!
                                • joaopedrogallo
                                  • Feb 2023
                                  • 13
                                  • Brazil
                                  Hi there!
                                  Can someone do the CLEAR ME on this BIOS?
                                  Its taking too long to show SAMSUNG logo.
                                  Thank you in advance!
                                  Best regards!
                                    • 22286
                                    Originally posted by joaopedrogallo
                                    Hi there!
                                    Best regards!
                                    Post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
                                    • SHASHIGHOST
                                      • Jan 2024
                                      • Sri Lanka
                                      https://www.badcaps.net/forum/troubl...11#post1339711
                                      ITS WORKED FOR ME. THANKS BRO...........
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
                                      • mkdj
                                        by mkdj
                                        Dear all,
                                        10-19-2025, 04:41 AM
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • haitham sharabati
                                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                        by haitham sharabati
                                        Hello engineers 😀,
                                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                        🔧 Device Info:
                                        - Model: HP 15-da2007ne
                                        - Product Number: 8XF55EA#ABV
                                        - Serial Number: CND0338P0D
                                        - CPU: Intel Celeron N4000
                                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                        💀 Problem:😅
                                        - Device shows “Administrator Password”...
                                        08-07-2025, 04:54 AM
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        08-05-2025, 05:12 AM
