lenovo z40-70 bios
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    lenovo z40-70 bios
    Can someone fix my original bios file please the problem boots slow at stock at lenovo and sometimes it boots fine.here is the orignal dump attached
    the problem with this sometimes when it boots fine after restarting its hard to turn on again and sometimes turns on the stack at lenovo the goes off and lights blinking
    • 21932
    Re: lenovo z40-70 bios
    here ,try this.
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      ok thanks ill try this
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        not working with your bios lights blinking only cannot turn on
          • 21932
          The ME region is clean,based on your old bios,i made another bios and checked with hex editor its the same. Flash your old bios back, you said sometimes it boots fine,so get the bios update from lenovo and flash it in windows it will update the EC as well.
            • 21932
            Try these bios and EC dumps .
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              thanks i flashed with this bios here i got in this forum https://www.badcaps.net/forum/showth...=aclua%2Faclub same board id. its working fine display comes for about 5seconds and boots fine without CMOS battery but when i soldered the CMOS battery at first i will boot, then after shutdown it cannot turn on again, unlike when cmos battery removed from the board boots fine but showing display sometimes 5 sometimes 10 seconds to display but once it display it boots fine without cmos battery.
              • Andrew_R
                Banned
                • Jun 2018
                • 91
                • Poland
                This BIOS is for your motherboard + DMI and windows Key (taken from your old BIOS file) .
                - Motherboard - ACLUAB
                - BIOS Version - 9BCN91WW
                - Model - Lenovo Z40-70
                - MTM - 20366
                - SN - YB07671XXX
                - SN Board - 1036409000XXX
                - UUID - 42FEFE30-2DDB-11E4-A81828D244DE3XXX
                - Mac Addres - 28-D2-44-DE-XX-XX
                - Windows KEY : J6GG7-NM9J8-8MJ8J-8KD6K-7XXXX
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  @Andrew R thank you very much for the bios laptop now back to normal and working fine!
                  • cestech
                    • May 2025
                    • PerĂº
                    hola! voy a probar esta bios a ver que tal queda... es mi primera vez colocando una bios.
                    Hi! I'm going to try this BIOS to see how it looks... it's my first time installing a BIOS.
                    in English please...
                    • peste
                      peste commented
                      Editing a comment
                      Don't forget to make a backup copy of your original bios...
                  • lucaszmn
                    by lucaszmn
                    Problem:
                    Initial Findings:
                    • I concluded that the
                    08-12-2025, 03:01 PM
                  • Wahaz
                    by Wahaz
                    10-30-2023, 08:42 PM
                  • grimacelord
                    by grimacelord
                    Hello there.
                    History:
                    03-15-2023, 03:29 PM
                  • to5it0
                    by to5it0
                    10-24-2025, 01:35 AM
                  • jendkkd jeje
                    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                    by jendkkd jeje
                    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                    10-11-2024, 03:12 PM
