emc 2674 bios
  • tugrul63
    • May 2015
    • 94
    • türkiye
    emc 2674 bios
    hi
    i need EMC 2674 bios dump.
    model: A1389
  • tugrul63
    • May 2015
    • 94
    • türkiye
    Re: emc 2674 bios
    cryptic
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • greelidd
      K6604J Vivobook RTX 4070 BIOS Dump Request
      by greelidd
      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
      09-01-2025, 06:14 PM
    • TyMercer
      Can I flash a working BIOS from one computer to another of the same make, model, etc?
      by TyMercer
      Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
      11-13-2025, 09:39 PM
