ASUS R556LA Need BIOS dump
  • KvnTM
    • May 2018
    • 434
    Hey guys,
    i need the bios dump of an ASUS R556LA without Nvidia GPU. Thanks!
    Board is X555LD rev 3.3
    • 20840
    Re: ASUS R556LA Need BIOS dump
    https://www.badcaps.net/forum/showth...ghlight=X555LD
    • KvnTM
      • May 2018
      • 434
      Thanks, got it!
      It was a few posts below. The X555LABF1601 one.
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Anchar777
        ASUS P1412CE need BIOS DUMP
        by Anchar777
        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
        06-26-2025, 03:39 AM
      • kcp0085
        Request BIOS dump for ASUS FA617NS-A16.R77600
        by kcp0085
        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
        Specs:
        - ASUS TUF FA617NS-A16
        - CPU: AMD Ryzen 7
        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
        Thanks in advance!​
        05-02-2025, 12:52 AM
