Samsung XE300TZC AKA ATIV TAB 3
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    This tablet is dead as it doesn't boot or allow to enter bios.
    One or two times I was able to make it boot somewhere where I saw the error:
    security version mismatch detected. make sure you are updating to a new version of the system firmware or contact your support representative
    Error code = 0x10000001
    wait 3 seconds to restart
    Typical solution found online: Replace the motherboard.
    So I'm wondering if a BIOS dump file can be found so I try to flash/reporgram the BIOS
    • 21932
    Re: Samsung XE300TZC AKA ATIV TAB 3
    Hold down the power button and volume button to get into bios.From there disable security checks .
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      More better if you post your original dump...
      from this site i got the bios version,
      http://webcache.googleusercontent.co...&ct=clnk&gl=id
      your bios version : P??ADC
      Now you can download the update bios from samsung site,
      http://sbuservice.samsungmobile.com/...WIN_P07ADC.exe
      but... extracting from ITEM_20140304_21325_WIN_P07ADC.exe, you got BIOS REGION ONLY, no ME region ,no decript region etc..
      so if you hard to find other dump, post your original and someone can repair for you here..
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
        Samsung ATIV XE303C12 Chromebook Specification for Upgrade or Repair
        This specification for the Samsung ATIV XE303C12 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the XE303C12 boardview and XE303C12 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
        09-06-2024, 05:27 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Lexsmash85
        Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
        by Lexsmash85
        Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
        Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
        USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
        08-06-2025, 03:41 AM
