HP DMI Tool NBDmiFit
Re: HP DMI Tool NBDmiFit
Hi guys,
ive got hp elitebook 2170p, MPM unlocked but when i use dos tools [hpbq142] [NbDmiFit_2.12 doesnt work] or even windows [wndmifit] and fill missing fields then nothing is saved.
I dont know what to do. When i try to boot in UEFI from EFI file [bootx64.efi] then i have blinkin cursor in left upper corner.
Can someone can help me?Comment
Wdmifit did it
But I still have message of not committed, what do I need to do now?Comment
I am struggling, but I feel this thread has information I need to put me on the right track. If I need to create a separate post, or post in another thread/area, please just let me know.
I own an HP ENVY 750 that randomly lost its System Board CT Number. Going through the BIOS, I can see the SKU and Serial Number are still intact and I have the CT number recorded on a sticker inside the OEM case.
This is my first go-around with an HP hardware issue of this nature, but I am a systems engineer by trade, so I'm not afraid of poking around.
I have tried making a bootable FreeDOS USB drive and copied over the contents of NbDmiFit versions 2.09, 2.10, and 2.13 (each version was a separate attempt), all resulting in the same error message: "Vendor code not supported in this package"
I see references in this thread to unlocking the MPM, but I'm unfamiliar with that term so I assume I haven't done that. However, I don't think I'm even there yet since the error I'm receiving in the NbDmiFit script indicates I'm missing the necessary HPyyxxxx.exe file (If I understand the process correctly).
I'm not sure why this happened as I wasn't messing with the hardware of this pre-built machine at the time of the error. I haven't updated the BIOS recently, and I haven't done Windows updates this week (and the PC has been rebooted several times since the last updates were applied).
I'm not so much concerned with WHY this happened as getting this fixed. This is the only Windows machine I have at home. I'm hoping someone on here can help me fill in the gap of what I'm missing.
Here's a breakdown.
1. My desktop PC is an HP ENVY 750-437cb running Windows 10 Home (build 1903 or 1909, I don't remember which).
2. As stated, only the System Board CT Number is missing from the BIOS.
3. I have an additional laptop that I'm using to help fix the PC. It's an HP Elitebook running Ubuntu 18.04 LTS. A lot of instructions I've found thus far are for a Windows machine fixing this problem and I've had to adapt those instructions for Linux (e.g. run 'dd' on FreeDOS.img instead of Rufus.exe to create a bootable USB media).
4. In the BIOS, I have disabled Secure Boot and enabled Legacy Boot.
5. I can boot into FreeDOS just fine, but running NbDmiFit.bat produces the error "Vendor code not supported in this package"
Any information/help is appreciated.Comment
Hi Guys,
I have an issue with my HP elitebook 2470p. Every time I power it on:
Warning Machine is not in committed state
No motherboard has been replaced.
I try to use NBDmiFit tool but I can't fill any serial number (v.2.13).
The BRAND tool can't be used becase the descriptor is locked.
Lateset BIOS already installed.
Windows starts fine.
Please can you help me to fix this issue?
ThanksComment
Try an older version such as HPBQ138_patched,and try the commit tool, it only works on older hp`s .Hi Guys,
ThanksAttached FilesLast edited by SMDFlea; 12-31-2019, 04:01 AM.Comment
Hi, I recently replaced a motherboard in a HP 24-B016 Pavilion AIO and it works great except the error message on boot up that it is missing product, serial, etc. I have tried the nbdmifit which I think is too old. I have also tried Wndmifit, but this says my board is not supported.
Anyone know which version / tool to use for this machine? Does the newest version of tool support all machines and older? I have tried 2.09 and 2.13. Thanks in advance!Comment
I was able to fix this by unlocking the MPM via nbdmifit uefi utility and then using HP BCU program located https://ftp.hp.com/pub/softpaq/sp100...0/sp100599.exe . I hope this helps someone and saves them some time!Comment
I have a HP ProBook 650 G1 - when I start the laptop I am getting a message Product Information Not Valid. I know I am supposed to write the info manually, but I am not sure how. Which tool should I use to write the product info manually? I tried using HDMI tool and DR. Bios, but it's not working. MB manufacturer is Inventec.
Waiting for helpful advice...
MPM is unlocked.Comment
i have hp elitebook 2560p. Everytime i power on it gives me error product infromation is not valid and i have bios updated to f66 is there anny solution i tried v 2.13 also but didn't work for me. any solution?Comment
Yes post here bios dump i will fix your error..Comment
I have a HP Probook 450 G1 that used to have a admin password, I flashed the bios with a clean one to remove the password (using a ch341a).
After that I used the Wndmifit64.exe utility to program the serial number, sku and all that good stuff. after that I locked the mpm with the bat file. but I still have a the "Warning!! Machine is not in committed state". I did boot in EFI shell to run the startup.nsh but the it give me a "cannot determine ME capability". I also tried in dos, running the brand.bat, but it gives me a similar error.
I'm sure sure what to do next... any suggestions?Comment
Clean the ME region.If you don`t know how to do it post your bios backup in the bios requests section for cleaning.I have a HP Probook 450 G1 that used to have a admin password, I flashed the bios with a clean one to remove the password (using a ch341a).
			by rex98HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
The DMI Tool given here are for personal use only.
DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
from it, and that you please credit the author...-
							Channel: BIOS Requests ONLY!
			by tsavpynDear all,
I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
Now I have a problem that I am unable to dump my BIOS into bin file.
My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
I searched for FPT but there is no Linux version and none of them work.
I hereby request a copy of Intel Flash Programming Tool for Linux x64.
I would really appreciate it if anyone...-
			by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
			by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
			by tony359HI all,
I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because... - Loading...
