HP DMI Tool NBDmiFit
  • Aditya11ttt
    Adi
    • Feb 2019
    • 190
    • India
    #141
    Re: HP DMI Tool NBDmiFit
    new link https://drive.google.com/file/d/19i5...ew?usp=sharing update
    Originally posted by Aditya11ttt
    • Shay_G
      • Aug 2020
      • 7
      • iL
      #142
      upload ur old dump plz
      MOD EDIT: NO dumps in this thread, Upload to the bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40
      How to dump my biosto file and where to upload¿¿
        • 21889
        Here is where bios requests go: https://www.badcaps.net/forum/forumdisplay.php?f=40 .You need to backup your bios using an SPI bios programmer.
        • feherhollo
          • Nov 2019
          • 110
          • Hungary
          #144
          I have replaced my motherboard and reprogrammed the UUID, serial (except the feature byte and build Id).
          The problem is that during boot it says :
          "Warning Machine is not in committed state"
          When I open the DMI firmware tool it says MPM is not in unlocked mode and the "Commit only" button on the bottom is greyed out.
          Where can I find the feature byte and build Id how can I unlock MPM? I read SMC.bin has to be generated based on the UUID and the SN
          This is my problem also with factory new 1040 G1 motherboard.
          I need to reunlock MPM to correct the fields.
            • 21889
            See post #137 .Whats your serial number ?
            • feherhollo
              • Nov 2019
              • 110
              • Hungary
              #146
              Originally posted by smdflea
              see post #137 .whats your serial number ?
              2ce4210ns1
              That post is to lock the MPM
              I need to unlock. Tried every method. No success. The MPM locked
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                #147
                Send error bios file i will fix or remove error.
                • feherhollo
                  • Nov 2019
                  • 110
                  • Hungary
                  #148
                  The problem is I added the SKU in the wrong format and locked the MPM
                  This caused not in commited mode error.
                  I don't want to deal with DUMPS, I prefer the original method.
                  If no any other way I will dump the chips.
                  This was factory new replacement motherboard from HP
                  • imranromi
                    • Jan 2015
                    • 1290
                    • Pakistan
                    #149
                    If you done without bios dump tell me i wait..
                    • feherhollo
                      • Nov 2019
                      • 110
                      • Hungary
                      #150
                      I can done without dump if I have the correct SMC.bin file. That will unlock the MPM again and I can modify the faulty settings with HP DMI Tool. Lock the MPM again and every boot error will disappear
                      Just need the generated SMC.bin file for my serial and UUID
                      • feherhollo
                        • Nov 2019
                        • 110
                        • Hungary
                        #151
                        This is current bios. Latest version. Machine not in committed state!!
                        Featurebyte and Build ID missing. MPM locked
                        I don't know exactly whats the problem. SKU format is invalid or what??
                        MOD EDIT: Bios requests go in the "Bios Requests ONLY!" section, not in this thread
                        • imranromi
                          • Jan 2015
                          • 1290
                          • Pakistan
                          #152
                          Read bios chip via programmer.You save file without programmer..
                          • feherhollo
                            • Nov 2019
                            • 110
                            • Hungary
                            #153
                            Yes I know but if I read the chip and open wit hex editor, its only zeros, can't see any content. I have multiply programmers and softwares.
                            Always have difficulties with this 1040 G1 and G2
                            In my case the problem is Machine not in committed state because I have not set the vPRO functionality and locked the MPM
                            If I unlock the MPM again I can commit the board and voila. Problem solved.
                            What can you do with the dump?
                            https://youtu.be/Q1tMphdzTIo
                            • imranromi
                              • Jan 2015
                              • 1290
                              • Pakistan
                              #154
                              i can solve all problem via bios dump.read complete bios and send if you want solve problem.No have other way if you want waste time you can try via software.
                              • feherhollo
                                • Nov 2019
                                • 110
                                • Hungary
                                #155
                                Okay I can read the chips but how? Both of my programmer read out looks like nothing...
                                Okay I will send you the dump and you will check it.
                                  • 21889
                                  • feherhollo
                                    • Nov 2019
                                    • 110
                                    • Hungary
                                    #157
                                    I don't request bios.
                                    I just like to get my problem solved. Locked MPM to Unlocked MPM
                                    • feherhollo
                                      • Nov 2019
                                      • 110
                                      • Hungary
                                      #158
                                      Here is the dumps https://www.badcaps.net/forum/showthread.php?t=88318
                                      • Shay_G
                                        • Aug 2020
                                        • 7
                                        • iL
                                        #159
                                        i dumper and uploaded my bios
                                        https://www.badcaps.net/forum/showth...517#post986517
                                        please unlock my MPM,
                                        many thanks
                                        • feherhollo
                                          • Nov 2019
                                          • 110
                                          • Hungary
                                          #160
                                          many thanks
                                          Sorry MPM unlocking only possible with SMC.bin file which is unique for each unit generated from serial and UUID. Only HP can do.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
