HP DMI Tool NBDmiFit
  • Shay_G
    • Aug 2020
    • 7
    • iL
    #161
    Re: HP DMI Tool NBDmiFit
    Originally posted by feherhollo
    Sorry MPM unlocking only possible with SMC.bin file which is unique for each unit generated from serial and UUID. Only HP can do.
    after playing with the spi flasher i ended up with my laptop NOT powering on ()and the charge led is blinking with orange color button forever no matter if i put the charger and remove the battry,
    how can i fix this¿ or maybe this laptop is dead forever¿
    • feherhollo
      • Nov 2019
      • 110
      • Hungary
      #162
      You need to erase and reflash both chips 2MB + 16MB with working clean .bin files.
      Can find here in forum. You may use a CleanME version of the 16mb chip.
      • Dodge101
        • Sep 2018
        • 8
        If you want to lock and unlock MPM on some machines i suggest you goto this post
        https://www.badcaps.net/forum/showpo...1&postcount=12
        download Ver 2.13. Make a USB bootable pen drive. When you boot from the pen drive it automatically runs a program in UEFI mode that locks and unlocks the MPM.
        I've used it on the following models that I've had repair:
        HP Spectre Convertible - 1DL99EA#ABU
        HP Notebook 15-bs507na
        HP Pavilion X360 13-u009na
        HP Laptop 15 15-bw029na
        • xeniachile
          • Sep 2020
          • 5
          • chile
          #164
          somebody can extract Setup module or Setup PE32 for you, from the file
          attached so you can generate IFR text file
          is a bios insyde h20 F.2A Rev. A rev3.7
          • syairien
            • Sep 2018
            • 9
            • indonesia
            #165
            Sorry, does anyone support the all-in-one type 20-c414c cellphone, I tried them all but they couldn't
            • theace8869
              • Sep 2020
              • 5
              I have the an HP Pavilion 17-f053us and replaced the motherboard and I used the the NBDmifit tool to fill in everything. The only thing that it ask now is "Product Name" and the NBDmifit tool i used via dos does not have an option for that. Is there something I missed or do I have to use something else to fill this in?
              • theace8869
                • Sep 2020
                • 5
                Been trying to "Set Product name" with different tools but I cant find any tool if any that lets you "Set Product Name".
                • backgammon
                  • Oct 2020
                  Signed up to say that I have exactly the same issue. Everything else is fine, except for "Product Name".
                  • Supra2020
                    • Oct 2020
                    • Россия
                    #169
                    thanks!!!
                    • backgammon
                      • Oct 2020
                      Still no luck with My HP Spectre X360 (13-4014TU) replacement motherboard. Can't unlock MPM to update product name in windmifit, NBDmifit doesn't contain product name. Means I still have a prompt every time I start the computer which is quite annoying. HP apparently aren't sending out smc.bin files due to security concerns. Really frustrating I think I'm going to have to live with the boot prompt...
                      • backgammon
                        • Oct 2020
                        Also, some people have mentioned that you can boot in "UEFI mode". That said, the files within nbdmifit are .bat files, which typically do not run in a UEFI shell. Can someone elaborate on the proper procedure to boot a "UEFI USB"? I have been using Rufus to flash freedos, but this only boots in BIOS mode, and nbdmifit works here (and I'm assuming it's also unlocking MPM since it lets me change things), but I can't set a product name.
                          • 21417
                          The DMI tools include a pdf with the instructions on how to make a UEFI bootable key. Try hp BCU bios config utility as well. Also see post #137 in this thread,there`s a few youtube videos and an MPM tool that might help .
                          • theace8869
                            • Sep 2020
                            • 5
                            If you find something let me know as I really want to fix that issue.
                            • dbone5000
                              • Jul 2020
                              • usa
                              #174
                              Originally posted by Exa
                              Thanks you !
                              It had helped me to put back S/N and P/N for an unsupported old EliteBook 8460p with brand new system board got on eBay from a brocker.
                              What exactly did you do to make it work?
                              • danandrei96
                                • Dec 2018
                                • 17
                                #175
                                Hi! Can someone help me with my HP bios please? Dump here https://www.badcaps.net/forum/showth...23#post1004223
                                  • 21417
                                  See post #137 for some videos that will help .
                                  • danandrei96
                                    • Dec 2018
                                    • 17
                                    #177
                                    I already went through the whole thread before commenting. I tried the config tools from post #137 but they just return access denied and still the MPM is locked sadly
                                    • danandrei96
                                      • Dec 2018
                                      • 17
                                      #178
                                      SOO.. in case anyone else is wondering, I actually managed to unlock the MPM by running UEFIMPMUNLOCK.EFI in nbdmifit 2.13 from the EFI shell. Even though the program says it's not supported on my system (2.14 would be the right version, but has no UEFI) . After MPM unlock I can use the normal tools nbdmifit or wndmifit to write the details
                                      • GGN
                                        • Dec 2020
                                        • France
                                        #179
                                        Hello!
                                        I am trying to unlock the MPM on my Elitebook 840 G2 because I failed the initial branding after I changed the motherboard.
                                        I tried the above method, and after I launch UefiMpmUnlock.efi in EFI shell, I receive the following message: HP MPM protocol is not present.
                                        What do you guys think I am missing here?
                                        I also tried to find a way to unlock the MPM via BIOS programming with no success. Could someone tell me how to find the byte controling MPM state in the BIOS?
                                        Thanks!
                                        • falcon147
                                          • Apr 2014
                                          • 6
                                          • tanta
                                          #180
                                          what version for HP 640G1 please i wanna solve {warning machine is not in committed state}
                                          what can i do
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
