HP DMI Tool NBDmiFit
  • Murtaza527
    • May 2018
    • 257
    • Malaysia
    Re: HP DMI Tool NBDmiFit
    thanks but my problem not solve its happen with me many time i tried to read file which is using hp in 840 G3 and G4 that is 25Q64JV and 25Q128JV
    my programmer read this but if i read from original bios IC and i write on anyother bios IC
    that is not working above file also i read but not which file you provide i try to write but after that laptop just restarting every time not properly on can anyone tell me about this bios chip how i can read and write perfectly
    i have two programmer
    RT809F ISP Programmer and SOFi SP16-B Professional Programmer
    • bps123
      • Jan 2019
      • india
      Originally posted by ala_borbe
      thank you for info, i did not know this... it will sure help
      smc.bin file not failure in hp 840g2
      • ManniLudde
        • Feb 2019
        i hope this is the right Thread. Is it possible to change my serial Number on my Elitebook 850 G5? If so, is there any Tutorial which VErsion of the DMI Tool i need. I tried the HP BCU 4.0.25.1 Tool, there i can only change the bios options and not the Serial. Thx for ur Help!
          • 20643
          Try WnDmifit from windows,its included in the nbdmifit folder.Try any version from 2.10 on the first page of this thread.
          • ManniLudde
            • Feb 2019
            Thank u, which Tool do i have to use to change the serial number, the BiosConfigUtility64.exe? I used the BiosConfigUtility64.exe from the HP BCU Toolkit sp88497.exe. There it wasnt possible the change the serial number, uuid etc. it was read only.
            • ManniLudde
              • Feb 2019
              when i try running the wndmifit64.exe the following error is shown:
              "MPM is not unlocked. Will not be able to set BIOS settings. Please escalate with the UUID to get SMC blob to unlock MPM.
              Can anybody plz help me?
              • ugore
                • Feb 2019
                is there any tool that supports proone G3 AIO?
                • ManniLudde
                  • Feb 2019
                  What do u mean, inside the DMI Toolset?
                  • blacksun-encoder
                    • Mar 2019
                    hello friends,
                    i have a problem with my hp 17-y055ng. at startup the noteboosk shows serveral problems with product information, system board ct and so on. all i have repaired with the tool NbDmiFit V2.13. The errors will not be shown at startup.
                    but in the bios on the first side, there is a "born on date" with ÿÿ/ÿÿ/ÿÿÿÿ
                    How can i change this too?
                    Please help me and sorry for my bad english.
                      • 20643
                      Originally posted by blacksun-encoder
                      hello friends,
                      http://*******/viewtopic.php?f=53&t=10021&start=80
                      english translation -
                      Born On Date (Warranty Start Date)
                      New version of the utility launched with the / clrwsd or / CLRWSD flag
                      (case is significant, and only two of these options are allowed)
                      clears the start date of the warranty period to 00/00/0000.
                      To correct this incident, we translate the system time to the time we need,
                      Install HP Support Assistant, turn off the Internet, and simply launch
                      % ProgramFiles (x86)% \ Hewlett-Packard \ HP Support Framework \ Warranty \ HPWSD.exe.
                      When rebooting, go to the BIOS and enjoy the result.
                      PS I do not attach HPWSD.exe, because without installing HP Support Assistant in the system
                      The utility is non-functional, apparently because of the HPSF services that work with WMI.
                      • blacksun-encoder
                        • Mar 2019
                        Thanks for your reply.
                        but what means "new version of the utility launched with /clrwsd. Which version of nbdmifit is here meaning?
                        i have wrote the serial number and model number with windmifit under windows and not with the dos boot usb pen.
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          #32
                          hello friends,
                          1 condition if you have old bios save post here and how to come this error?
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            #33
                            Or use tool hp BCU.. i think all bios data show in windows i remove many time error (Manufacture programming mode is unlock) i open cmd and type something have youtube video for support.
                            https://www.youtube.com/watch?v=UhjdPWlyX-0
                            Try this methods when save file open if you see sn,pn i think is show bios date.00/00/0000.
                            • myjyd
                              • Mar 2019
                              • 235
                              #34
                              Thank you
                              • winx62
                                • Apr 2019
                                I have an HP 280 G2 SFF PC
                                2.13 when booted says "does not support this platform"
                                Does anyone have a newer release?
                                Thanks so much. This is a very informative forum.
                                • chrisj979
                                  • May 2019
                                  I have a similar question how do I make it bootable so I can run NbDmiFit.bat? Creating a Win 8 PE boot disk from ADK it says cannot execute program, Win 10 PE says it "does not support this platform.
                                  • jasko_jacker
                                    • Oct 2014
                                    • 1137
                                    • italy
                                    #37
                                    Use tool as rufus or similar , it's an open version of old dos
                                    • bakre
                                      • Dec 2014
                                      • 105
                                      • Zwolle
                                      #38
                                      Thanks for every one
                                      • pmudzengi22
                                        • Jun 2019
                                        • South Africa
                                        #39
                                        Guys. Can I have detailed instructions on how to add system info on the HP 625.
                                        • ccannon
                                          • Jun 2019
                                          • US
                                          #40
                                          I am looking for a dmi to help me with an All-In-One manufactured around 2017. Haven't had any luck locating it.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
