bios chip problem after 100% programmed using CH341A!
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Re: bios chip problem after 100% programmed using CH341A!
    Good point. I will check that too.
    Thanks for your help mockingbird. .
    I will post back after flashing couple of bios dumps and test them.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      i can fix your dump if you post it
      Im Back... sort of...
      • Weelcup
        TopTech
        • Oct 2017
        • 307
        really? that will be super.
        actually I downloaded the dump bios file from online. I downloaded three different dump files from three different websites. I attached them all. and all are supposed to be for the MB I have.... but all gave me the same results. around 15sec black screen then shuts off.
        your help is very appreciated ... thanks
        kindly find the attached files...
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          no, i need your dump... not some random internet dump
          • Weelcup
            TopTech
            • Oct 2017
            • 307
            Please note that the MB was not working when I got this laptop. And that is why I tried to flash the bios.
            This is the the dump file I got it from the laptop itself at the very first time.... hope it be OK. .
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              #26
              nope, cant help on this model... sorry
              • Weelcup
                TopTech
                • Oct 2017
                • 307
                thanks for trying buddy...
                • CuUuzZzA
                  • Mar 2022
                  • CZECHIA
                  #28
                  Hi guys, got a SOLUTION!!!
                  Problems with ERASING and VERIFICATION are caused by a badly made VOLTAGE on the CH341A - Bios chips usually run 3.3V. And it's alright with CH341A BUT the DATA LANES are fed by 5V. That's the reason the why you can't erase your chip, because of incorrect communication between your chip and the CH341A chip.
                  I've spent the whole weekend on trying to flash my Bios Chip via this programmer device. There are some TUTORIALS on the Internet how to FIX the Voltage for 3.3V by SOLDERING.
                  I don't have things for soldering. So I started thinking how to decrease voltage from my usb port from 5V to about 3V by connecting many hardware or something to the 1 USB Port. I've connected 1 USB Hub on this hub 1 usb lamp and a PS4 gamepad. Make a usb cable's length as long as possible. To this hub I had plugged the other hub and into this hub my CH341A. And BAAAM!!! After trying erasing, there was written: CHIPS ARE BLANK!
                  You just have to try connecting different things and longering usb cables for overloading the usb port and trying erasing your chip. Erasing has to take several seconds ( not 0:00:00 ). I think I have some problems with as programmer, so then I did it via CH341A PROGRAMMER v1.18. You will also need installing 2 drivers right from their chinese website ( don't be scared, it's not HTTPS ). Trust me, those 2 files are 100% clean and ok:
                  1. CH341PAR.EXE - this is a CH341WDM.INF device driver ( 06/05/2021 )
                  http://www.wch.cn/downloads/CH341PAR_EXE.html
                  2. CH341SER.EXE - this is a CH341SER.INF device driver ( 01/18/2022 )
                  http://www.wch.cn/downloads/CH341SER_EXE.html
                  I have done it successfully on WIN 8.1 on an old laptop and then on WIN 10 on my pc without any problems as well.
                  Hope it will help somebody!
                  GL&HF guys!!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12441
                    #29
                    New bios file
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • intelg
                      HP Elitedesk 800 G6 lost BIOS admin password
                      by intelg
                      Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                      Here is the hardware identification specs:
                      HP EliteDesk 800 G6 Desktop Mini PC
                      Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                      BIOS ver S21 Ver. 02.05.01 01/05/2021
                      Born on date: 07/26/2021
                      SN MXL11841GN
                      SKU 3X8V9UCHABA
                      UUID 8116E79EF6FFE94DB0B98A3188270C5C
                      SYSTEM BOARD ID 8710
                      SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                      11-03-2023, 02:05 AM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
