Lenovo Ideapad 310-15ABR bios needed
  • philipp57
    • Apr 2018
    • 10
    • Bayern
    Hello!
    One more question, maybe someone has the right bios for: LENOVO-IdeaPad-310-15ABR Motherboard CG516.NMA 741.Rev: ver.1.0
    Thank you!!!
  • philipp57
    • Apr 2018
    • 10
    • Bayern
    Re: Lenovo Ideapad 310-15ABR bios needed
    Does anyone have the bin file ???
    • subroto
      • Oct 2015
      • 230
      • Bangladesh
      Here it is...
      Enjoy Bro...
      • philipp57
        • Apr 2018
        • 10
        • Bayern
        Thanks alot!!!!!!
        • philipp57
          • Apr 2018
          • 10
          • Bayern
          Thanks Subroto it worked great !!!!
          THANK YOU!!!
          • gerardo
            Engineer
            • Feb 2016
            • 59
            • Argentina
            Originally posted by subroto
            Here it is...
            Enjoy Bro...
            Thank you!
            • ofiden
              • Jan 2020
              • 4
              • Uruguay
              Here it is...
              Enjoy Bro...
              • dmacagno
                • Feb 2019
                • 3
                • Argentina
                Thanks....Excellent!!
                • f-bone
                  • May 2013
                  • 96
                  • Greece
                  hi guys! thank you for all the help.
                  I needed to ask if this motherboard requires an EC firmware incase the I/O controller is replaced or it reads it from the main bios.
                  • peste
                    • Dec 2016
                    • 13701
                    • ROMANIA
                    see if the I/O chip is programmable, or not... if it is programmable, it definitely needs EC bios.. here on the site you can find data about programmable and non-programmable I/O chips..
                    • SalmanNR
                      • Sep 2017
                      • 11
                      • Banjarmasin
                      thank's Sir
                      • redtrash
                        • Apr 2023
                        • 3
                        • IT
                        I've used it too with CH431A programmer, the laptop I've found in the trash is now alive again. 😉😁
                        Just one info about, the BIOS was edited to delete all the personal info about the original owner, I guess, but are those info needed somehow or I can leave it "invalid"?
                        Also, the bios is not recognizing the external RAM (4gb ram stick) but only the soldered one, but this may be a problem on the ram stick.
                        Thanks!
                          SMDFlea commented
                          Editing a comment
                          If you saved a backup before flashing the bios the DMI should still be in your backup
                      • djharold
                        • Aug 2015
                        • 247
                        • COLOMBIA
                        Here it is...
                        Enjoy Bro...
                        thanks work for me
                        • redtrash
                          • Apr 2023
                          • 3
                          • IT
                          I did it, but looks too corrupted.
                          Anyway, about the RAM, I was mistaken, I've cleaned the contacts and now works.
                          • Chivo77
                            • Aug 2024
                            • 15
                            • Argentina
                            hello! I've succesfully replaced and flashed my EC (thanks a lot btw), but now the fan runs at full speed and never stops (except obv. when powered off). This laptop came to me not powering on, had to replace EC, pmic and reflash corrupted system bios (I have the original dump). Any hints?
                            • peste
                              • Dec 2016
                              • 13701
                              • ROMANIA
                              post S/N, full name and model, motherboard model, TYPE,etc.
                              post the contents of the bios chip even if it is corrupted..
                              • Chivo77
                                • Aug 2024
                                • 15
                                • Argentina
                                first of all thanks peste. I should have taken more care in my description of the problem
                                Here's the data:
                                http://support.lenovo.com/qrcode S/N:PF0QUJXF MO:PF9XB7407059 MTM:80ST0087AR
                                I should add some observations i made:
                                1- This MB works just fine except for the fan speed problem? Loads windows and everything else.
                                2 - The fan starts at slow speed and then accelerates when entering boot selection
                                3 - The signal EC_FAN_PWM starts modulating ok, and then goes to 3v at the time detailed in point 2 and stays there
                                4 - I dont know what to expect in EC_FAN_ANTI​
                                5 - related to 4, I have yet to search info about 5 wire fans
                                thanks again
                                • peste
                                  peste commented
                                  Editing a comment
                                  post the bios in "bin" format..
                              • peste
                                • Dec 2016
                                • 13701
                                • ROMANIA
                                bios extracted from Lenovo website update for 310-15ABR Laptop (ideapad) - Type 80ST
                                DMI 2A3000 - 2A4FFF​
                                • Chivo77
                                  • Aug 2024
                                  • 15
                                  • Argentina
                                  hi there, badcaps web rejected the bin format, I see you uploading as .rar, will do the same with the original bios. I dont know if I understand what to do with yours. I can tell you that I've already downloaded that bios from the lenovo site, and updated it within windows. In the process it updated the ec bin too.
                                  • peste
                                    • Dec 2016
                                    • 13701
                                    • ROMANIA
                                    now you posted the contents of the chip correctly..how did you extract the contents of the bios chip???
                                    • mkdj
                                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                      by mkdj
                                      Dear all,
                                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                      Here the steps I have taken to fix the laptop:
                                      - downloaded latest BIOS from Lenovo Website...
                                      10-18-2025, 03:43 AM
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • joven016
                                      Lenovo Ideapad S145 need working bios HELP!!
                                      by joven016
                                      Problem is blinking power led only
                                      i don't know exactly if it's s145-15igm or s145-14igm
                                      have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                      Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                      Already tested some of posted bios here
                                      S145-14igm - success but invalid serial and not booting on OS
                                      S145-15igm - success with serial and some other info in bios but still not booting on OS
                                      already tried installing new windows but always booting on bios setup
                                      windows installer flash drive detected on...
                                      08-21-2025, 10:55 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
