hp 840 g4 ME Clean
Clean me region hp 840 g4
Please some one to clean me region here is my dumpAttached FilesComment
Re: Clean me region hp 840 g4
Have you tried cleaning the bios already with FIT,is that your own bios backup or one you got from somewhere else. Post your original bios backup .Comment
Have you tried cleaning the bios already with FIT,is that your own bios backup or one you got from somewhere else. Post your original bios backupAttached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by iulik17dHello everyone!
The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
- Loading...
