using attach file to remove password.with this file no password but display is coming very late......any help
hp 840 g4 ME Clean
Re: hp 840 g4
Try and give feedback.Attached FilesComment
Re: hp 840 g4
Hmm..... Really dont no why then. perhaps masters like ala borbe should have a look.Comment
Re: hp 840 g4
Here is an image created with f.i.t.try and reply.Attached FilesComment
Re: hp 840 g4
the unlocked file in the first thread me version is 11.6.11.1202.the original with password is 11.6.12.3202.try this one.Attached FilesComment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
Channel: BIOS Requests ONLY!
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by iulik17dHello everyone!
The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...-
- Loading...
