VN7-791G-77GZ bios dump
  • dmusic
    • May 2015
    • 14
    • bulgaria
    Please for help,VN7-791G-77GZ bios dump
    (Wistron Poseidon 840M MB)
  • nacer
    • Feb 2016
    • 130
    • alger
    Re: VN7-791G-77GZ bios dump
    you got it
    • demisoc
      • Jun 2019
      • 6
      Which programmer did you use for this? My EZP2010 programmer doesn't detect this chip (25B64BSIG). I tried to program it while it was still on board. I'm wondering if my programmer is not compatible or if it's because I tried programming the chip while it was still soldered to the board.
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
