VN7-791G-77GZ bios dump
  • dmusic
    • May 2015
    • 14
    • bulgaria
    Please for help,VN7-791G-77GZ bios dump
    (Wistron Poseidon 840M MB)
  • nacer
    • Feb 2016
    • 130
    • alger
    Re: VN7-791G-77GZ bios dump
    you got it
    • demisoc
      • Jun 2019
      • 6
      Which programmer did you use for this? My EZP2010 programmer doesn't detect this chip (25B64BSIG). I tried to program it while it was still on board. I'm wondering if my programmer is not compatible or if it's because I tried programming the chip while it was still soldered to the board.
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • grimacelord
        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
        by grimacelord
        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
        Motherboard model number: DA0PAMB46A1 REV: A
        Secondary motherboard model number: 0PAB
        SKU: 685K4UA
        Serial number is: 5CD3223BJP
        Recently reflashed this laptop with latest BIOS and once...
        05-07-2024, 08:06 AM
      • zlr8r
        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
        by zlr8r
        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
        cheers
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        MOBO: RO 15 17 WHL 2GB MB / 18706-2
        Attached;
        1. My saved bios using a programmer
        2. Dells Bios updater .exe (v1.16)
        3. Dells Bios recovery file
        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
        5. Image of ME...
        12-18-2023, 03:08 PM
