lenovo g475 no voltage on bios
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need help on this LENOVO G475 la-6755P, the problem 19v,5v and 3.3v present but there is no voltage on pin 8 of the main bios chip but there is 3.3v on pin1 but pin8 no voltage.I checked EC chip voltages is present.Anyone please help on this
  • ibnhassana
    • Apr 2018
    • 5
    • france
    Re: lenovo g475 no voltage on bios
    you must flashing thee bios
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      I already done flashing the main bios that i got here in the forum but still no 3.3v on pin 8 should i flashed the ec?
      • ibnhassana
        • Apr 2018
        • 5
        • france
        flash the ec and main bios
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          thanks ill try and give update soon
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            I flashed both main and EC still the same issue cannot turn on all voltages present eXCEpt for the main bios chip pin8.i checked JPWRB1 pin6 and pin7 NOVOBTN# AND ON/OFFBTN# which has a voltage of 3.3v.anyone can help me please
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              bios above working i found the problem i flashed above problem and short pin 7 and 8 it turns on and display comes, the power switch board is shorted now i need to make a jumper 2 wires to switch on
              • pabloroggeri
                Electronic
                • Apr 2015
                • 90
                • Argentina
                LA-6755P Rev 1.0
                Hello,i need bios file LA-6755P REV 1.0. I know that this bios has already been requested in the forum but the file they uploaded from the main bios has 2049kb, 1000kb is left over and it does not allow me to save the memory correctly. Can someone upload the correct files?
                • peste
                  • 13436
                  • ROMANIA
                  Re: LA-6755P Rev 1.0
                  READ THIS...
                  Post the full name and model of the laptop, the S/N, the original bios, etc.
                    • 21679
                    The 2,049KB file at post #4 has been edited and replaced. Follow peste`s advice though, make a backup,post the serial number
                    • lambungay2023
                      • Mar 2023
                      • 16
                      • philippines
                      Need help Bios File ,
                      • peste
                        • 13436
                        • ROMANIA
                        read post#9..
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • erico
                          Lenovo X1 Carbon BIOS not getting voltage
                          by erico
                          First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
                          I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
                          So far these are my diagnostics:
                          When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
                          When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
                          If i plug the battery...
                          05-02-2024, 02:40 AM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • grimacelord
                          by grimacelord
                          Hello there.
                          History:
                          03-15-2023, 03:29 PM
                        • jendkkd jeje
                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                          by jendkkd jeje
                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                          10-11-2024, 03:12 PM
