Dell Alienware 17 R3 Bios Dump
  • wildmermaid
    • Mar 2018
    • 6
    I am looking for dump for the mentioned laptop. Bios available on the Alienware support site is a .exe file which the programmer is unable to read.Any help ?
  • sancheti81
    • May 2014
    • 191
    • India
    Re: Dell Alienware 17 R3 Bios Dump
    post your old dump with model number and serial number may someone can help you
    • wildmermaid
      • Mar 2018
      • 6
      I dont have any old dump as such. But i will attach the latest Bios file from Dell official site.Model is Alienware 17 R3
      • Pascal Komlassan
        • Jan 2017
        • 806
        • TOGO
        hello please i need the bios of this manchine Alienware M17x R2
          • 20758
          Theres a modified bios here:
          https://www.bios-mods.com/forum/Thre...Options?page=9
          • wildmermaid
            • Mar 2018
            • 6
            This is the original Dell latest Bios rom file for the requested model.
            • Pascal Komlassan
              • Jan 2017
              • 806
              • TOGO
              Thank you very much. But your bios did not work for my machine. mine is 4096ko it turns on the machine but it does not boot on USB or hard drive
              • IDislikemakingLogins
                • Feb 2017
                • 38
                • moon
                So had a Alienware 17 R3 come in, would briefly turn keyboard back-light on then off, rarly it would turn on to a black screen and beep 7 times. Trying to use the hold esc and ctrl, plug in, power on recovery wouldn't do anything. Opend found 4 rom chips 3 1m and 1 16m chips.
                uh4 had the bios and uefi stuff on it. grabed the bios from dell and extracted it using Alienware_15R2_17R3_1.2.8.EXE /writehdr. Using UEFITool, extracted the uefi image as is from the .hdr file it made and opend my dump, to replace the bios region as is. After re uploading it seams to boot agen. Beeped 5 times but after powering down and back up whent away aprintly its to hard to make a cmos battery error text screen beter to make the system beep and have no screen thanks dell.
                  • Feb 2017
                  • 38
                  • moon
                  So found out it wouldn't boot internal drive but a usb cdrom with Super Grub Disk would let me still load an os.
                  Downgrading bios to 1.2.8 and loaded each update to 1.6.1 seams to have cleared that problem.
                  Bios would take forever to load / get to boot, disabling tpm fixed this.
                  System would also not shut-down would just go black screen and stay on forever.
                  System would beep 2 short beeps randomly on reset / power on, would boot normal after bitching about ram changing.
                  Re-dumped bios and ran me_cleaner, System boots faster, shut-downs properly and no more beeping.
                  I tryed updating the me but meinfo wouldn't work and the drivers didnt recognise. I now have a reason to hate intel a little more.
                  Winbond flash chip "W25Q128.V" (16384 kB, SPI)
                  • alihomee
                    • Dec 2012
                    • 1574
                    • malaysia
                    used ur above file and it works perfectly
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      Hi Guys,
                      I have the a somewhat similar issue where the Laptop (Alienware 17 R3) turns on but shuts off within 6 seconds. I was able to go to recovery but the following is display:
                      ROM Image is not loaded
                      ROM Image update denied
                      thanks in advance for any help. Do i need a Bios flash?
                      • peste
                        • Dec 2016
                        • 12698
                        • ROMANIA
                        Originally posted by waakye
                        Hi Guys,
                        posteaza biosul original al laptopului..
                        • waakye
                          • Dec 2018
                          • 340
                          • Electronada
                          Thanks Peste for replying.
                          The original Bios is attached
                          • waakye
                            • Dec 2018
                            • 340
                            • Electronada
                            can anyone help me with a clean bios for Alienware 17 R3 ,
                            • waakye
                              • Dec 2018
                              • 340
                              • Electronada
                              Can someone check my original bios posted at #13 and let me know if there is an issue with the bios bin please.
                              • hardware1
                                • Sep 2021
                                • 2930
                                • N/A
                                Here's your New BIOS, try it and give me results.
                                Service Tag: 9N44BG2.
                                all donations are welcome,
                                • waakye
                                  • Dec 2018
                                  • 340
                                  • Electronada
                                  @hardware 1
                                  I flashed the bios with the one you posted and the machine turns on fans spins and immediately turn off. When I remove the ram and turn the machine on, the laptop beep 2 for ram failure.
                                  Thanks 🙏
                                  • waakye
                                    • Dec 2018
                                    • 340
                                    • Electronada
                                    Any help guys?
                                    • jhanra
                                      by jhanra
                                      in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                      11-02-2024, 04:19 AM
                                    • fiveOfox
                                      Dell Alienware 15R2 Bios recovery.
                                      by fiveOfox
                                      Hello all! I'm new here but looking to get help with my Dell Alienware 15 R2. I have dumped the bios and have already tried another bios online and it worked but i would like to have all my info in the new bios but i also don't know my service tag as it was worn off the bottom so I'm hoping someone could help get it from the old bios image and get me a working image for my machine that has all the correct info!
                                      I have provided my original corrupted bios and the bios i used to get the machine working.
                                      Thank you!...
                                      08-24-2024, 07:48 PM
                                    • bondminer009
                                      Need Bios for Latitude 7650 (No Original / dump bios file)
                                      by bondminer009
                                      Good Evening,
                                      Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                                      Thank You
                                      Salam,
                                      Three
                                      11-12-2024, 07:48 AM
                                    • mido50
                                      Dell Precision T5500 Bios dump
                                      by mido50
                                      Hi, I need Dell percision T5500 bios dump
                                      I tried extracting the ones from dell's website
                                      but they are not the same size as the one saved feom the bios chip.
                                      or if their is a way to make the one from dell's website work when programed to bios chip.
                                      Thank you in advance for your help.
                                      05-23-2024, 06:07 AM
                                    • joshAU
                                      BIOS file for N550JK (original dump attached)
                                      by joshAU
                                      Hi all.
                                      I'm looking for a BIOS file for an Asus N550JK.
                                      I have a Asus R552J, which I believe is identical to the Asus N550JK.
                                      I downloaded the latest BIOS (210) for the R552.
                                      It is named N550JKAS.210.
                                      The BIOS file is however only 6mb in size.
                                      I've read the chip with a CH341A programmer and verified the file.
                                      That file is actually 8mb in size.
                                      I'm wanting to remove the BIOS password from this unit.
                                      It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                                      08-09-2022, 08:06 PM
