bios hp DAY31AMB6C0 rev.C, please
    • 20367
    Originally posted by Niksob
    Greetings,
    I have an HP Envy 17-k206na laptop. I wanted to update the BIOS via the update executable.
    I found an update executable for the HP ENVY 17-k000
    https://drivers.softpedia.com/get/BI...0-64-bit.shtml
    I ran the executable and everything seems to be fine, expect the laptop now tells me that there is no battery detected.
    Then I noticed that the laptop is labeled in a series, for example k000, k100 and k200. So mine would be k200.
    I later found a executable update for k200 on the same website
    Since both BIOS update files sp92961.exe are identical in name, size, and file details, would it be safe to assume that there would be no difference in installing k000 instead of k200? 😑
    I really don't want to think about the idea that I may have messed up my BIOS and now some features won't work.​
    Thread merged..... .Just run the exe make a recovery USB. It will choose the right bios to update your laptop.
    • Niksob
      Niksob
      • Mar 2025
      • 10
      • Austria
      #42
      I ran the sp92961.zip file you provided, but I noticed that after the BIOS recovery, the laptop does not detect the battery. 😫
      I have tried several times updating the F.57 BIOS, different download files for the k000, k100 and k200 models, but the problem still persists. I also did a clean install of Windows 10 and the problem persists. My laptop does not detect the battery now?
      I have also tried disabling and then enabling the Microsoft ACPI-Compliant Control Method Battery driver in Device Manager, but nothing helps. I have even tried uninstalling the ACPI driver and also the Microsoft AC adapter and then restarting the laptop, but the problem persists.
      I have no idea what else to do...😢
        SMDFlea commented
        Editing a comment
        Try another battery.
    • Niksob
      Niksob
      • Mar 2025
      • 10
      • Austria
      #43
      In that case, I will look to buy another battery. The fact is that I bought a replacement Green Cell 2600 mAh battery (HP82PRO) around September 2019 and the battery was always charged at about 90% when plugged into AC. I find it very strange that the battery would suddenly die in that time frame. 😐
      • Niksob
        Niksob
        • Mar 2025
        • 10
        • Austria
        #44
        I bought a brand new Patona 2200 mAh battery and I still get the message "No battery is detected". I really don't know what else it could be... 🤔 Since the BIOS update, the battery is no longer detected.
          SMDFlea commented
          Editing a comment
          Maybe there`s a problem with the charging circuit.
      • Niksob
        Niksob
        • Mar 2025
        • 10
        • Austria
        #45
        I honestly don't know what the problem could be. I know you can't fully diagnose a computer just by looking at a photo, but I don't see anything wrong with the laptop. The white ribbon connecting the battery pins to the motherboard was installed correctly, in my opinion. I'll try taking it apart again and reconnecting it again, but I honestly doubt it.
        • Niksob
          Niksob
          • Mar 2025
          • 10
          • Austria
          #46
          Status update on the battery issue... I honestly can't believe what the problem was, but the laptop now recognizes the battery and works/charges flawlessly.😀👍
          The problem was that there was no blue pull tag on the battery ribbon cable that connects to the motherboard. If I hadn't bought a new battery to test, in case my used battery was the problem, I would never have noticed the missing blue pull tab while troubleshooting. As shown in the photo on insidemylaptop.com, you can clearly see two blue pull tabs on each side of the white ribbon cable. While troubleshooting, I kind of felt that the ribbon cable was not securely attached (it felt loose) under the locking tab where the pull tab was missing, so I tried placing a small piece of paper on top of the cable to press the connectors all the way in and all of a sudden the laptop recognized the battery!😃
            SMDFlea commented
            Editing a comment
            Thanks for the follow up, i`m very happy you got it fixed :-)
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • Bloodhoundje
          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
          by Bloodhoundje
          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
          I have desoldered the bios chip (GigaDevice...
          03-16-2024, 03:12 PM
