zed air 14 bios reset
  • walupapz
    • May 2017
    • 21
    • philippines
    i have zed air 14 which is i accidentally change settings in bios what i remembered is disabling fastboot and usb 3.0 then after saving settings and hit restart now it started not to function keyboard and mouse pad. i tried to find cmos battery but it doesnt have so i tried experimenting the board for being hopeless. im lucky, i resetted my bios deafult settings by shorting pins of the bios. what i just remember is putting tweezer to the 4 pins of bios 1234 just make them short while laptop is powered on then wait till goes off then try to power again your laptop without shorting pins of bios. if 1234 not work try 5678 pins to short.this advice is to those who want to risk only and do not like sending back to service center
    "do it at your own risk" because i triedalready and it works 105%
  • Kiran Prakash
    • Jan 2019
    • India
    Re: zed air 14 bios reset
    Thank you very much, it worked, 200% :-)
    • Kiran Prakash
      • Jan 2019
      • India
      Actually on ZedNote 11
      • alam419967
        • Mar 2019
        • Saudi Arabia
        thanks for your kind support
        but , i want to know , how to power on its means battery is connected am i right reply please
        or with out baattery short the pin, and also let us know all 4, pin is short at the same time.
        • alam419967
          • Mar 2019
          • Saudi Arabia
          i got the same problem, but i found 2, bios chips on my mother board, so which one i have to short and also let me know shorting all 4, together..
          • 8678
            • Jan 2017
            • 6
            • bangladesh
            sir zed note 14i bios pls
            • YG007
              Asus BIOS How To Reset To Default Settings?
              by YG007
              Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
              I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
              06-05-2023, 08:22 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • llek100
              HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
              by llek100
              Hello, sorry for the long post, I just wanted to include any details that might help.
              A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
              I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
              So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
              First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically...
              09-18-2024, 09:15 AM
            • Hinkz
              Lenovo m90q gen 4 hidden BIOS settings.
              by Hinkz
              Hello All,
              I recently upgraded my Lenovo m920q to a m90q gen4 (13th gen intel).
              I had much success following some very helpful guides on unpacking the m920q BIOS that Lenovo had on their website to find out hidden options such as cfg lock & overclocking lock, then using grub to change these settings.
              I'm having much less success with the m90q gen4 and latest BIOS on the Lenovo website (https://support.lenovo.com/us/en/dow...tation-p3-tiny), when I unpack this BIOS and use UEFITool to browse its contents I can't seem...
              06-28-2024, 05:37 PM
