bios dump elitebook 840 g3
  • Vesko356
    commented on 's reply
    Really? Because I just tried it and it worked without any problems with your dump.
    Try again.
  • dr.tubes
    replied
    Originally posted by dr.tubes
    I qouldnt unlock my bios with HPunlocker tool.
    Can someone unlock it for me please.
    I tried with RCunlocker , when I insert my bios.bin in exe file program , it always tells me there is an error , and it doesnt unlock.
  • struart
    replied
    Originally posted by qayyum786
    Try again with a clean me
    if no luck than clean ram slot with IP & brush,
    Resold ram slot pins cold solder also cause for no ram detect
    remove data & clock switching ic make a jumper in between both data and clock line
    Looks like itsa a hardware issue.
    Thanks for help anyway.....
  • qayyum786
    replied
  • struart
    replied
    TRY
    Completly not booting on this one.
    Power button blink every second and that it
  • qayyum786
    replied
    Originally posted by struart
    Hello
    I think i have corrupted BIOS can someone look at it?
    Laptop gives 3 long beeps and 2 short wich means faulty memory but its not. RAM work on other laptops ok.
    840 G3 Elitebook
    Serial:
    5CG7362P9J
    Motherboard:
    6050A2892401-MB-A01
    TRY
  • struart
    replied
    Hello
    840 G3 Elitebook
    Serial:
    5CG7362P9J
    Motherboard:
    6050A2892401-MB-A01
  • hoaca388
    replied
    Originally posted by classicandy
    YES, 850 g3 ---> 840 g3.
    It is currently showing as HP EliteBook 850 g3 but i want it to show as HP EliteBook 840 g3 instead and also have the SN i assign to it.
    THANKS.
    HP EliteBook 840 G3 Notebook PC
    HPUnlocker is old,try the newer version RCUnlocker
  • dr.tubes
    replied
    I have motherboard HP ProBook 840 G3 ,
    6050A2892401-MB-A01,
    SN PFKZU00WB5659K
    My bios is locked , can anyone please send me unlocked bios or unlock my bios in attachment?
    My old locked bios is in attachment.
    Thnx.​
  • classicandy
    replied
    Originally posted by hoaca388
    In short, do you want to change SN from : HP EliteBook 850 g3 MAIN 1 ---> HP EliteBook 840 g3 MAIN 1 - Model & SN Edited or vice versa.
    THANKS.
  • hoaca388
    replied
    Using BIOS Config Utility, I got an Access Denied error as well. Is there anything I am missing?
    I reverted back to the 850 g3 bios bin before attempting the BCU and it is stated I can't change the model because it is Read-only of which i still tried anyways with no luck . Right now, I am stuck. If i can get a working BIOS for 840 g3, it will be useful. One i have that works shows up as ZBook 14 G3.
  • Vesko356
    BIOS guides, methods, resources and tools
    https://www.badcaps.net/forum/troubl...rces-and-tools
    3. Password removal by laptop brand
  • dr.tubes
    replied
    SN PFKZU00WB5659K
    Thnx.​
  • classicandy
    replied
    Hi, Please i need help modifying a BIOS bin for HP Elitebook 840 g3
    I bought a replacement motherboard which happens to be for HP Elitebook 850 g3 and i want to use it to replace a faulty HP Elitebook 840 g3 motherboard. I have attempted to transfer the model name and serial number from the faulty 840 g3 motherboard to the 850 g3 motherboard but it turned out unsuccessful. I tried using my knowledge of changing Apple SSN, HWC and Checksum on it and I was able to input the correct serial number and model name but wasn't able to rectify the checksum error. After putting the BIOS Chips back on the motherboard and powering on, it displayed CMOS reset page upon first boot and after pressing 'ENTER' key to restart, it didn't display again and started fan spinning.
    I will be glad if anyone here can assist me in sorting it out or direct me on how to fix the checksum for it.
    I have attached the original untouched BIOS bin for the 850 g3 and the modded BIOS [16mb and 8mb] as well. I have also attached the error i got from using ME Analyzer too
    Model: HP Elitebook 840 g3
    S/N: 5CG71004S9
    ProdID: Y3R95UC#ABA​
    Board No: 6050A2892401-MB-A01
    Thanks.
    Use Bios Config Utility.
  • TIRCEN90
    replied
    Hello, can someone help me clean my bios, it doesn't send a video
    HP 840 G3
    sn: W3G52UP
    product: L3C65AV
    board: 6050a2892401-MB-A01
    Thank you​
  • classicandy
    replied
    S/N: 5CG71004S9
    Thanks.
  • minhdigital
    replied
    Originally posted by smallvhin
    Master pls help to unlock master🙏 TIA
    SN: 5CG7502BQ4
    Send to you
    Read post 902 .Havn`t you tried RCUnlocker ?
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • mediadoctor
    Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
    by mediadoctor
    Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
    07-20-2025, 09:38 AM
  • Guest
    Elitebook 850 G5 BIOS bricked
    by Guest
    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
    I assume the BIOS update failed, so I searched for the BIOS chip.
    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
    Can the corrupted...
    03-24-2025, 01:21 AM
  • MDSI
    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
    by MDSI
    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
    Details:
    Model : HP OMEN 17-an012nf
    Motherboard Part Number : DAG3BAMBAF0 REV : F
    Serial Number (S/N) : 5CD7280D51
    BIOS chip : Winbond W25Q64VSIQ
    Programmer : EZP2023+
    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
    I already...
    07-28-2025, 07:11 AM
