NEO MODEL.: LC89---Need Bios dump pls..
  • techcare
    • Nov 2017
    • 18
    • KOREA
    HELLLLPPPPP..tnx
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • greelidd
    K6604J Vivobook RTX 4070 BIOS Dump Request
    by greelidd
    Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
    Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
    09-01-2025, 06:14 PM
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
