Samsung R540 Bios Dump (BREMEN-C Rev 1.1)
  • tablet3rs
    • Aug 2013
    • 57
    • philippines
    hi guys i need bios dump for
    samsung NP-R540
    BREMEN-C Rev 1.1
    thanks in advance...
  • tablet3rs
    • Aug 2013
    • 57
    • philippines
    Re: Samsung R540 Bios Dump (BREMEN-C Rev 1.1)
    up up up
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Look here
      https://www.badcaps.net/forum/showthread.php?t=48461
      • tablet3rs
        • Aug 2013
        • 57
        • philippines
        thanks..
        appreciated
        • tablet3rs
          • Aug 2013
          • 57
          • philippines
          up we go...
          good day
          • tablet3rs
            • Aug 2013
            • 57
            • philippines
            up up up
            thanks
            • tablet3rs
              • Aug 2013
              • 57
              • philippines
              up
              • tablet3rs
                • Aug 2013
                • 57
                • philippines
                one more up...
                • fixfixit
                  • Jun 2010
                  • 14
                  • Sri Lanka
                  Here is a dump from a working Samsung R540 laptop, Motherboard BREMEN-C Rev1.1(100210)-4
                  • prypoy
                    • Jul 2019
                    • 3
                    • Украина
                    Thank you sincerely
                    • Rickless
                      • Jul 2020
                      • Philippines
                      Is there an update for bremen-c bios?
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • jeewantha
                        Samsung NT-R580 Bios Dump Required
                        by jeewantha
                        Hi Guys,
                        I need a bios dump for the following laptop.
                        Samsung NP-R580
                        Motherboard : BREMEN-M REV:1.0 (091112)-5
                        Serial Number : BA68-05578A 20
                        Thank you​...
                        05-20-2025, 05:03 AM
                      • grimacelord
                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                        by grimacelord
                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                        Motherboard model number: DA0PAMB46A1 REV: A
                        Secondary motherboard model number: 0PAB
                        SKU: 685K4UA
                        Serial number is: 5CD3223BJP
                        Recently reflashed this laptop with latest BIOS and once...
                        05-07-2024, 08:06 AM
                      • DynaxSC
                        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                        by DynaxSC
                        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                        11-06-2022, 05:22 PM
