Bios Programmer Suggestions
  • soninke_worrior
    • Nov 2017
    • 18
    • Gambia
    Hello Everyone!
    I want to buy a bios programmer. Which one will you suggest and why?
    Thank you!
  • STKR123
    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
    by STKR123
    Greetings badcaps community,
    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
    I learned that desoldering...
    10-29-2024, 06:03 AM
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • zlr8r
    looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
    by zlr8r
    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
    cheers
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    MOBO: RO 15 17 WHL 2GB MB / 18706-2
    Attached;
    1. My saved bios using a programmer
    2. Dells Bios updater .exe (v1.16)
    3. Dells Bios recovery file
    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
    5. Image of ME...
    12-18-2023, 03:08 PM
    by Vesko356
    08-11-2023, 03:27 AM
  • what_1282105
    Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
    by what_1282105
    Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
    02-14-2025, 07:27 PM
