ı need ideapad miix 510-12isk bios dump. thanks
Re: ideapad miix 510-12isk bios
have password
Attached FilesLast edited by tugrul63; 01-17-2018, 12:41 AM.Comment
Dear tugrul, the update file at lenovo site is less then your bios region and it seems encrypted. Sorry i dont have the knowledge to rebuild this particular bios. I request imranromi or ala borbe to look into it or anyone who can help him.Comment
hope this help you,if the password store at bios chip not at kbc chip.. because this extracted from lenovo
2kcn33ww.exe instead your bios ver. 2kcn29ww
your dmi will loose...
goodluck and please confirmAttached FilesComment
How you decrypted acer web update file? Can you share so that others can learn.Comment
for Lenovo using innounp -x after that you can using 7zip and cut with Hxd...
for Acer 7zip and Hxd..
tell me the example files you need to extract.. i ll try to explain for you..Comment
Thanks for replying rioreno. My query was about lenovo miix 510-12isk bios. Can you explain how to use this command innounp-x?? If you can attach the software or download link-that will be great. Thanks again for your time. Waiting for your reply.Comment
ideapad miix 510-12isk need bios
hi guys! i badly needed ideapad miix 510-12isk bios, anyone can help me.. tnx in advance..Attached FilesComment
Re: ideapad miix 510-12isk need bios
Try this and report, this bios from lenovo updateAttached FilesComment
Please can you decode password from bios dump?Thanks in advance.Attached FilesComment
bios extracted from Lenovo site update
DMI 200000 - 20018FAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
hi all
dumped MIIX 510-12IKB clean . -- worked on Bios lockedAttached FilesComment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM - Loading...
