Asus Eee pc 1015bx-whi032s dump bios
  • v11
    • May 2016
    • 44
    Please a bios dump,I have tried so far with 5 dumps,and do not fit.
    Please help... 1015bx-whi032s
    thank you.
  • cacla
    • Apr 2015
    • 442
    Re: Asus Eee pc 1015bx-whi032s dump bios
    try this one
    • v11
      • May 2016
      • 44
      Originally posted by cacla
      try this one
      No, it does not work, I tried.
      Thanks.
      • cacla
        • Apr 2015
        • 442
        Pls sent me sn form your notebook to find your dump
        • bachir2004
          • Feb 2015
          • 437
          • maroc
          Thanks.
          try this and reply.
          • v11
            • May 2016
            • 44
            Originally posted by bachir2004
            try this and reply.
            not work...thx
            • cacla
              • Apr 2015
              • 442
              By this sn there is 2 bios pls try this
              • cacla
                • Apr 2015
                • 442
                Is this solve your problem ?
                • v11
                  • May 2016
                  • 44
                  Yes, it works...with first in the list......100 % BEST..
                  Thank you very nice..
                  BR
                  • i.g.e.o
                    • Jun 2020
                    • Russia
                    Guys, good day!
                    I will up that topic because of it's my only hope.
                    So, I have a that netbook: ASUS Eee PC 1015BX-WHI138S, MB REV 1015BX 12.
                    And it has now BIOS version 0610, but it has problem: Fan not working, but if I blow to holes - it rotates very easy, also I clean it and lubricate it. So fan itself in excellent state.
                    Sometimes it starts, but after some time stops again and CPU temperature goes to 98C and shutdowns.
                    I think it maybe because BIOS 0610, and I try to downgrade it to 0404 but it gives me "Model name doesn't match". I have a USB stick 2Gb, and bios ROM file name 0404.ROM, it doesn't helps.
                    Can you please help me and provide way to downgrade bios to 0404? And maybe somehow can be fan working constantly at 100%?
                    Thanks and sorry for bad english
                    • Bilal@pc
                      • Jun 2021
                      • 38
                      • Algeria
                      thinks it works
                      -----1015BXO-ASUS-0604.zip
                      for 1015BX REV2.1G
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • kcp0085
                        Request BIOS dump for ASUS FA617NS-A16.R77600
                        by kcp0085
                        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                        Specs:
                        - ASUS TUF FA617NS-A16
                        - CPU: AMD Ryzen 7
                        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                        Thanks in advance!​
                        05-02-2025, 12:52 AM
