Remove_SMM... UEFI.
  • jointx
    • Jun 2015
    • 10
    • Czech
    #841
    Re: Remove_SMM... UEFI.
    Originally posted by Ghamidi
    try this file and valid with any key
    Thank you so much, this patch file work fine! Great job.
    • daasco
      • Dec 2017
      • 27
      • Lebanon
      #842
      Originally posted by aldopc
      Try this how it went with the x1 carbon patch
      not working
      it stuck ,look to pics in attachments
      • Ghamidi
        • Mar 2020
        • 306
        • France
        #843
        Originally posted by daasco
        not working
        • Cunninghood
          • Jun 2020
          • 21
          • Singapore
          #844
          I am new to this. So if i want to reflash bios to remove the password, I will need the original bios dump? I cannot just rewrite the patched bin file that I can find here?
          I have a T440 here. But unfortunately, the laptop was unable to power on after I program a patched T440.bin file that I got from here.
          • Cunninghood
            • Jun 2020
            • 21
            • Singapore
            #845
            This means I need the original bios dump. Then replace body for boot option and lenovotranslateservice using UEFItool, and then save a new image. After which I will reflash bios and I should be able to remove my bios lock right?
            • daasco
              • Dec 2017
              • 27
              • Lebanon
              #846
              same as before WITH NEW SCREEN
              • Ghamidi
                • Mar 2020
                • 306
                • France
                #847
                same as before
                1. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
                2. Insert other LOCK HDD OR SSD M.2 ( by the way use another laptop set up password lock HDD and remember your password )
                3. ReFlash BIOS with patched file
                4. The First Step Let Press Down and Still Keep Little Switch ( picture attached ) long time and The Second Step Let Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will showing "Press any key..". Wait about 10 to 12 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID. Do not disconnect the AC during this process!
                • psyche
                  • Dec 2014
                  • Ukrane
                  #848
                  Hi everybody! Is there any solution for T440p?
                  • daasco
                    • Dec 2017
                    • 27
                    • Lebanon
                    #849
                    1. Remove the battery cmos . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have no the main battery attached and the no battery cmos .
                    2. Insert other lock hdd or ssd m.2 ( by the way use another laptop set up password lock hdd and remember your password )
                    3. Reflash bios with patched file
                    4. The first step let press down and still keep little switch ( picture attached ) long time and the second step let plug in the ac adapter and wait for a few seconds, the laptop will start by itself (if not, press the power button and start it). You may hear some beeps then you will see the lenovo splash image, press f1 to get the svp password prompt and enter "1234" for svp and press enter. Next page will showing "press any key..". Wait about 10 to 12 seconds before pressing any key. Next it will display the warning message and the laptop hardware id. Do not disconnect the ac during this process!
                    i did all steps you mentioned and i press 1234 and hardware id appeared after pressing enter i wait for moment message appear that security reset
                    and pressed power button then again on but laptop stuck
                    you can see the picture
                    thank you
                    • Ghamidi
                      • Mar 2020
                      • 306
                      • France
                      #850
                      thank you
                      KEY :1234567
                      . Now you need to press Space twice
                      . You can now power off the lenovo and reflash the original dump
                      • Ghamidi
                        • Mar 2020
                        • 306
                        • France
                        #851
                        thank you
                        SEE THIS VIDEO https://www.youtube.com/watch?v=171_Wfm-e80
                        • daasco
                          • Dec 2017
                          • 27
                          • Lebanon
                          #852
                          I DID AND ITS WORKED
                          THANK YOU SO MUCH
                          • Ghamidi
                            • Mar 2020
                            • 306
                            • France
                            #853
                            i did and its worked
                            Thank you so much
                            you welcome bro
                            • 530v8
                              • May 2019
                              • 41
                              Can Anyone patch T470s ?
                              Is it same like T470?
                              Bootoption and Lenovotranslateservice?
                              • Ghamidi
                                • Mar 2020
                                • 306
                                • France
                                #855
                                Originally posted by 530v8
                                can anyone patch t470s ?
                                Is it same like t470?
                                Bootoption and lenovotranslateservice?
                                try this file and valid with any key exemple 1234567
                                • aldopc
                                  • Jul 2017
                                  • 477
                                  • Chilito
                                  #856
                                  not working
                                  There it was ready you just had to load your original dump and ready ...
                                  • 530v8
                                    • May 2019
                                    • 41
                                    thanks already solved with other patched bin file from here
                                    • daasco
                                      • Dec 2017
                                      • 27
                                      • Lebanon
                                      #858
                                      Do not give me a fish to eat, but teach me how to fish
                                      any one can learn me?
                                      Best Regards
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #859
                                        Read this topic from the beginning to end and then try following instructions you found.
                                        • alaasniper3
                                          • Jun 2014
                                          • 13
                                          • jordan
                                          #860
                                          can be unlock thinkpad with out patch?
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
