Remove_SMM... UEFI.
  • vinsun0399
    • Aug 2019
    • 38
    • Jakulin
    #761
    Re: Remove_SMM... UEFI.
    please help me with P50
    https://www.mediafire.com/file/d0mdt..._lock.bin/file
    • CraterM
      • Mar 2018
      • 180
      • Moldova
      #762
      Originally posted by vinsun0399
      Try
      • holu00
        • May 2020
        • 9
        • Mexico
        #763
        Originally posted by bsz
        First extract as is with UEFITool (use search) Lenovotranslateservice and Bootoption.
        Replace as is Lenovotranslateservice and Bootoption with the files you extracted.
        If you have black screen or freeze try ctrl+alt+del or power on/off few times. If not working try with a hdd with password.
        If you get no image and 5 beeps:
        Use a hex editor and fill with ff the following files:
        VSS2 store Data address: 800064h Body size: 26F9Ch
        VSS2 store Data address: 82701Ch Body size: 26FE4h
        FTW store Data address: 84E020h Body size: 1FE0h
        (ex. from address 800064h to address 800064h + 26F9Ch fill with FF)
        and replace EVSA store Base address: 880000h size: 20000h with the file attached .
        You can check the address and size in your bios dump with uefitool.
        Follow the post from dani981 post 490.
        I tried to edit my original L560 bios dump on my own including and testing
        (1) BootOption, LenovoTranslateService (1st version) without and with VSS2, FTW, EVSA
        (2) BootOption, LenovoTranslateService_patched (2nd version) without and with VSS2, FTW, EVSA
        I followed #495, #128 and #51 and the rest of this thread.
        Upload to "winbond 25q128fvsq" chip was always verified.
        I deactivated small and big battery, held the small switch, connected AC power, pressed start button (did no boot on it's own).
        But all 4 tests generated a 5&5 beep, black screen, no prompt or splash image.
        I have no clue any more what to do... I would like to do it on my own because I have 3 x L560 laptops I need to get password cleared.
        Thank's for helping!
        • xinside
          • Oct 2017
          • 8
          • Russia
          #764
          Hello. Trying to unlock the Lenovo X250. Inserted the bodies BootOption, LenovoTranslateService, SystemPpisNeededByDxeCore. Does not perceive the key. Please help with the dump modification, thank you.
          • aldopc
            • Jul 2017
            • 479
            • Chilito
            #765
            Originally posted by CraterM
            Really ???? Momentarily not exist a solution for gen 8/2 and 10
            Hello Crater query there is no patch for the 8th and 9th generation? I have a couple of 8th bios patched by egifixlab I can send you the files for you to review what they modify ..is un thinkpad x280 and X1 Yoga 3rd Gen with i7-8650u
            • dani981
              • Mar 2018
              • 89
              • Hungary
              #766
              This model not mec1633 kbc its not working patch. L460 motherbord kbc: npce388na1dx.
              • Karol
                • May 2016
                • 90
                #767
                But NPCE388NA1DX have flash (128kb) inside.
                L560 I unlock it my self.
                Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                • Karol
                  • May 2016
                  • 90
                  #768
                  Ther is 8th generation with 32MB BIOS flash it can't be done. I personaly I unlock L390, but on every start/restart it give 2204 error.
                  Now i'm stuck with this error.
                  The notebook work perfectly fine, but have this error.
                  https://youtu.be/4gESTIcSBGs
                  • alqotary
                    • Jun 2016
                    • USA.
                    #769
                    Password In Thinkpad
                    • sudhakar.sanet
                      • Mar 2014
                      • 27
                      • India
                      #770
                      i have lenovo w530 laptop with password & computrace enabled.
                      i can clear password with 24rf08, but computrace is still activated.
                      anyone pls help me in this.
                      i have attached the bin where its has password and computrace activated.
                      • Ghamidi
                        • Mar 2020
                        • 306
                        • France
                        #771
                        Originally posted by xinside
                        hello. Trying to unlock the lenovo x250. Inserted the bodies bootoption, lenovotranslateservice, systemppisneededbydxecore. Does not perceive the key. Please help with the dump modification, thank you.
                        try this file and valid with any key
                        • holu00
                          • May 2020
                          • 9
                          • Mexico
                          #772
                          Thank's for answering! So you patched your own bios dump only? What else did you do to unlock your L560? I hope I do not need to access another chip.
                          • Karol
                            • May 2016
                            • 90
                            #773
                            Send me dump, i will patch it for you when I have a little time free.
                            • bachir2004
                              • Feb 2015
                              • 439
                              • maroc
                              #774
                              what are options for security chip?
                              • holu00
                                • May 2020
                                • 9
                                • Mexico
                                #775
                                Yes, please. I would like to do it myself because I have the UEFI of two more laptops to patch. I do not want to waste your time for the other two.
                                aliencillo points in #157 to a possible reason for the 2x5 beeps. It may depend on a failed BIOS integrity test .
                                • bachir2004
                                  • Feb 2015
                                  • 439
                                  • maroc
                                  #776
                                  hey Karol I was talking about the error code in your video,for the security chip in the bios thre is an option for verification of "chip security",i do not remember well but you can deactive it to get rid of that message.
                                  Sorry holu00 I am not good at patching this lenovo,me too i ask for help anytime I have one to do.
                                  • holu00
                                    • May 2020
                                    • 9
                                    • Mexico
                                    #777
                                    I will not give up for now.
                                    Next I will try to lock a SSD for my L560 using ATA security which was recommended in #55 by alucard6666.
                                    For this I will use hdparm under Linux where the SSD is mounted as an external drive for preparation.
                                    I hope to get rid of the 2x5 beeps with this exercise.
                                    • alqotary
                                      • Jun 2016
                                      • USA.
                                      #778
                                      No one Can Help ?
                                      • Karol
                                        • May 2016
                                        • 90
                                        #779
                                        Originally posted by alqotary
                                        No one Can Help ?
                                        All the members who ask for help, it write in post ThinkPad model.
                                        @bachir2004
                                        From what I remember I checked that option, but I will check again.
                                        Thanks.
                                        • xinside
                                          • Oct 2017
                                          • 8
                                          • Russia
                                          #780
                                          Works, thanks!
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
