Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by Sjenja View Post
    Thank you for the patch, could you expand on a bit on the process on modding the bios ?
    Okay a bit of feedback here, this modded bios did do its magic , but now after I have flashed the old original bios back, it will not boot it just sits with black screen and no fan, no sound, should I clean the ME region or do something else before flashing the old bios back ?
    If the BIOS is original one, you don't need to clean ME Region.
    It's important after pach to start and enter in BIOS setup and load default settings (F9) then save. It is mandatory to do that in order to assert the configuration and ACPI tables.
    Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
      OK i figured out what was wrong, my soldering skills were bad. SO after the patch, do you mean to start on the original bios and load default settings or on the modded bios and enter the default settings? Just for my clarification. Thx
        With original!
        The patched one it will not showing you BIOS setup.
          Originally posted by CraterM View Post
          Comming soon for last generation!
          Next week I will test one method
          im waiting for your replay
          thanks
            Can someone please patch my x260 bios?
              With original!
              Yep worked well. thx. I also figured out there i whent wrong in modding the bios, BTW in my early attempts I inserted the BootOption in the lenovosetupstartupdxe and this made it possible to get into the bios and would only activae the mod when trying to change the SV password, but I think I used the wrong version of LenovoTranslateService, becaulse it would not accept any keys. I may explore that also, what do you think?
                Try
                  Hi Everyone
                  Can someone please help me mod the Helix 20cg Bios so that i can unlock it?
                    its strange i have unlocked several machines now all same model, some will not load the patched bios makenig 2x5 beeps and screen remains black, what is going on ? on other machines works repect, all same model.
                    Update: to fix this problem I used one of the other machines pached bios that worked on the original machine. Worked like a charm. Still dunno on why some patched bios files dont work.
                      Anyone got a Lenovo P50 20EQ bios? Im experimenting with that now. L560 modded bios that works on multiple units, have tested on two machines same bios no pass unlock. Added to archives at : https://www.badcaps.net/forum/showthread.php?t=81573
                        can someone please help patch this X260.
                          try this file and valid with any key
                          good luck
                            good luck
                            many many thanks it worked.Any solution for ssd password?
                              Lenovo ThinkPad Y1 Yoga 1st Gen.
                              Could someone please generate or provide patch file
                              Thanks so much
                                Thanks so much
                                Try this
                                  Sorry i not hava solution of SSD password
                                    Hey. please help remove SVP t480s
                                      does anyone have JTAG pinouts for MEC1653 on a t480s
                                      i see JTAG port under the WLAN but i don't think that's usable
                                        Originally posted by stevie View Post
                                        does anyone have jtag pinouts for mec1653 on a t480s
                                        i see jtag port under the wlan but i don't think that's usable
                                        Jtag should be universal, check
                                          what programmer u have ?
