Remove_SMM... UEFI.
  • CraterM
    • Mar 2018
    • 178
    • Moldova
    #381
    Re: Remove_SMM... UEFI.
    Edit.... last model? T490, T590???? Any solution?
    • dani981
      • Mar 2018
      • 89
      • Hungary
      #382
      This Patch not supported t490 t590!
      I found ebay sales 9th gen bios unlock.
      If someone buys it, please share it
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        #383
        Where is link?I have some lock laptop want to buy if trusted guy.
        • bsz
          • Feb 2020
          • 5
          #384
          Hi, can somebody help with T560 password.
          I tried to replace the two files, but I get black screen and 2x5 beeps.
          Thanks.
          • dani981
            • Mar 2018
            • 89
            • Hungary
            #385
            Reliable. Unfortunately, I do not know.
            I'm interested Bios patch.
            This is link
            • dani981
              • Mar 2018
              • 89
              • Hungary
              #386
              Thanks.
              Patched this Bios file.Please feedback to me
              • dani981
                • Mar 2018
                • 89
                • Hungary
                #387
                This is link
                This can be a scam, allservice does not fix 9th generation.
                This link
                • bsz
                  • Feb 2020
                  • 5
                  #388
                  Thanks. All ok.
                  • dammysholove
                    • Jun 2017
                    • 59
                    • nigeria
                    #389
                    Originally posted by bjhawfam
                    When I compare lenovotranslateservice and bootoption they come out the same in hex editor extract. Why does the patch I created not work compared to yours?
                    NEVERMIND I found it.. I was able to compare several files on here and found the changes.
                    FINALLY!!!! After comparing the files and using both a hex editor and UEFITool I was able to find my problem. I then used the original file and made a patch as well. When I run a comparison it comes back exactly as the patch xdrive55 created. Just had to replace one last region and BAM.. Will have to try it out. Thanks for your help xdrive55 and for all who posted in this tread that contributed.
                    please kindly post the full tutorial bro
                    • Jovica123
                      • Oct 2017
                      • 80
                      • N/A
                      #390
                      You have everything on this tread,read carefully.
                      • naonao
                        • Feb 2020
                        • 13
                        • UAE
                        #391
                        Hi Guys,
                        Could you please help me unlock those two bios for Lenovo ThinkPad X1 Yoga 2nd Generation ?
                        Type: 20JE-S4FN01
                        Type: 20JE-S45V01
                        Thank you in advance.
                        • dani981
                          • Mar 2018
                          • 89
                          • Hungary
                          #392
                          Originally posted by naonao
                          Hi Guys,
                          Type: 20JE-S4FN01
                          Type: 20JE-S45V01
                          Patched this Bios file.Please feedback to me.
                          • naonao
                            • Feb 2020
                            • 13
                            • UAE
                            #393
                            get Hardware id: 1612452998
                            enter key : 1234567
                            Worked like a charm for the first laptop.
                            I will try with the second one.
                            Thank you so much.
                            • siddiq
                              • Dec 2011
                              • 121
                              • Ghana
                              #394
                              Hello, I've tried patching a Lenovo X1 Carbon Gen 6 to no avail. I'm always getting an 8 beep error code and a blank screen. I want to know if its just about replacing the modules or additional steps have to be taken. I had an earlier X1 Gen 6 patched successfully in this forum (thank you dani981).But when I use that bios file, it gets to where I press F1 to enter setup and then it writes "entering setup..." and then nothing happens. I extracted the modules from the earlier patched bios and used them to patch this current X1, but all I get is 8 beeps. I want to know if UEFI Tools alone is enough. I will be grateful if this file will be patched for me. Thanks in advance.
                              • CraterM
                                • Mar 2018
                                • 178
                                • Moldova
                                #395
                                Try this:
                                • siddiq
                                  • Dec 2011
                                  • 121
                                  • Ghana
                                  #396
                                  Try this:
                                  Hello, and thanks for helping, but I am still getting 8 beeps..
                                  • cayenne
                                    • Jul 2017
                                    • 19
                                    • Eesti
                                    #397
                                    can anyone patch this one
                                    • ANDYSH
                                      • Jan 2020
                                      • UA
                                      #398
                                      Pls help me with patching x260 bios
                                      • borchello
                                        • Jan 2020
                                        • Russia
                                        #399
                                        Hi! pls help me with my t440! Thanks!
                                        • CraterM
                                          • Mar 2018
                                          • 178
                                          • Moldova
                                          #400
                                          Try
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
                                          • Topcat
                                            Dell Precision T1650 USB UEFI Booting BSOD 0xc00021a
                                            by Topcat
                                            I'm stumped with this one; it was a dropoff freebie. Blank hard drive, uefi/gpt booting from USB to install OS, never gets to installer startup screen.... Win10 21H2 BSOD with stopcode 0xc000021a. BIOS settings are what they should be; legacy boot off, secureboot off. Firmware updated to latest version (A28).
                                            It will UEFI boot & install mint 21 just fine. Will also legacy boot & install win7 and win10 just fine as well...just won't USB UEFI boot to the 10 installer...no clue as to why!
                                            System: Precision T1650
                                            CPU: Xeon E3-1220V2
                                            RAM: 16GB PC3-10600U...
                                            11-08-2022, 09:02 PM
                                          • Kambi13
                                            Asus S530U UEFI password Locked
                                            by Kambi13
                                            Hi there, recently my kid decided to mess with the uefi, don't even know how he got there and incredibly placed an Administrator Password (What's new!!!!). Of course now he doesn't know what he typed in, result, as soon as laptop boots up a password is asked. Now, I've been working with computers all my life, but my knowledge about this new UEFI chips is very limited. I've taken it out and with a rom programmer I can see a bunch of stuff in it. Does anyone know the location where the passwords are stored?
                                            The UEFI Chip is a Gigadevice GD25B64C and the orginal rom dump is attached.
                                            08-12-2022, 11:29 AM
