Remove_SMM... UEFI.
  • didouche1200
    • Oct 2016
    • 373
    • 82679911441
    #321
    Re: Remove_SMM... UEFI.
    Can i help me tout patch m'y bios
    • dani981
      • Mar 2018
      • 89
      • Hungary
      #322
      Originally posted by noregret70
      Hi dani981, can you help me with this T450s , i try patch it but notebook freeze at thinkpad logo. This one have i7 cpu, i patch same one with i5 without problem.
      This is file name power pass. Maybe Power on password?If supervisor password flash this file.If you mean the Power-on password then see p. 34 of thehttps://download.lenovo.com/pccbbs/m...sp40g54937.pdf
      • dani981
        • Mar 2018
        • 89
        • Hungary
        #323
        Please feedback to me
        • Jovica123
          • Oct 2017
          • 84
          • N/A
          #324
          Do you insert lenovotranslatesevice and bootoptions or somerhing else ?
          When I patch file from didouche1200 and compare it with your patch,they are not same...
          • noregret70
            • Jan 2020
            • 11
            • Russia
            #325
            User enable all possible password on this one . Thx for help this patch work, it wait a bit long after i press f1 but finaly work.
            • didouche1200
              • Oct 2016
              • 373
              • 82679911441
              #326
              i try patched enter any id but laptop freeze at logo and dont enter setup bios
              • iTec
                • Oct 2017
                • 32
                Hey everyone! I'm just looking for some clarity on the patching process if possible.
                Correct me if i'm wrong, the files that need to be replaced are:
                1- BootOption
                2- LenovoTranslateService
                If that's true, then which section in the BIOS that those files are to be replaced? As I see BootOption for example in different sections and different Header-Offset.
                A clear explanation is really really appreciated.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #328
                  As I told before, use the search to find only LenovoTranslateService. Replace that. Then scroll a bit up or down and you should see BootOptions. Replace that.
                  • didouche1200
                    • Oct 2016
                    • 373
                    • 82679911441
                    #329
                    The problème isolved i just flashed with original dump bios' thanks bro 'tel me how to patch bios
                    • sudhakar.sanet
                      • Mar 2014
                      • 27
                      • India
                      #330
                      i patched lenovo x1 carbon 3rd fen for bios password
                      patch was successful.
                      Now i am getting 7 digit hardware id
                      Hardware id : 6084682
                      can anyone generate the key?
                      if any one has key generator , kindly share as it can help
                      • derick1
                        • Aug 2018
                        • 19
                        • Slovakia
                        #331
                        AFAIK key is 3056124
                        • sudhakar.sanet
                          • Mar 2014
                          • 27
                          • India
                          #332
                          Thank you very much
                          the key worked
                          • didouche1200
                            • Oct 2016
                            • 373
                            • 82679911441
                            #333
                            Please i need patched bios for x270
                            • didouche1200
                              • Oct 2016
                              • 373
                              • 82679911441
                              #334
                              Please i need to patch file bios x270
                              • dani981
                                • Mar 2018
                                • 89
                                • Hungary
                                #335
                                • didouche1200
                                  • Oct 2016
                                  • 373
                                  • 82679911441
                                  #336
                                  thanks wor biosked ;please tel me how patch
                                  worked bios
                                  • cayenne
                                    • Jul 2017
                                    • 19
                                    • Eesti
                                    #337
                                    Any solution for T480s
                                    • dani981
                                      • Mar 2018
                                      • 89
                                      • Hungary
                                      #338
                                      • Ljubisa2707
                                        • Nov 2019
                                        • 6
                                        • Bosnia and hercegovina
                                        #339
                                        Can you help me I have lenovo t450 and x240 with bios supervisor pasword, when I patch bios file laptop freze on first screen, can you patch file for me please
                                        • cayenne
                                          • Jul 2017
                                          • 19
                                          • Eesti
                                          #340
                                          Thanks , worked perfectly on T480s
                                          and for L450 the password was in ps2408 chip , like on older models.
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
