Lotus-14cml code:ba41-01992a bios
  • sancheti81
    • May 2014
    • 191
    • India
    Need bios file for samsung
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: Lotus-14cml code:ba41-01992a
    Samsung NP535U4C
    Lotus-14CML
    BA41-01992A
    • sancheti81
      • May 2014
      • 191
      • India
      thanks elsid79 i will check and inform you
      • sancheti81
        • May 2014
        • 191
        • India
        Originally posted by elsid79
        samsung np535u4c
        Lotus-14cml
        ba41-01992a
        thanks its working
        • sancheti81
          • May 2014
          • 191
          • India
          hi elsid79 display is fine with your bios but its not showing any bootable device
          no hdd detecting
          no dvd writer and not booting from usb also
          • Elsid79
            • Aug 2015
            • 47
            • Ukraine
            try it
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              if you still curious , try this full dump extracted with gzip from samsung site...
              hxxp://sbuservice.samsungmobile.com/upload/BIOSUpdateItem/ITEM_20140923_21429_WIN_P07RAR.EXE
              goodluck...
              semangaaatt
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                what was original problem with platop?
                do you have backup bios from your laptop?
                Im Back... sort of...
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • to5it0
                  by to5it0
                  10-24-2025, 01:35 AM
                • maanee11
                  Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                  by maanee11
                  Hello Everyone,
                  I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                  It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                  In the website, you can only see specs etc.
                  I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                  11-08-2025, 04:08 AM
                • m1ch43lzm
                  by m1ch43lzm
                  Hi everyone
                  09-06-2025, 05:47 PM
                • Citymin
                  Samsung NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha) Bios File Please.
                  by Citymin
                  HI all.
                  I need Bios dump File for
                  NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha - 15inch).
                  My Samsung Galaxy Book laptop Flex Alpha has no display and won't boot.
                  09-14-2025, 06:12 PM
