Asus X502c bios dump needed
  • salawayon
    • Nov 2012
    • 568
    • philippines
    motherboard infos:
    Asus X402CA REV: 2.1
    i attached my backup..
    thanks..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X502c bios dump needed
    100% working dump. Good luck
    • salawayon
      • Nov 2012
      • 568
      • philippines
      i tried your dump but the unit is still dead and no led indicator at all... i tried other dump and it show charging led ON but the unit is still dead...
      thanks..
      • cacla
        • Apr 2015
        • 442
        I have 2 dumps try and sent msg
        • hondaxr
          • Jun 2014
          • 21
          • portugal
          Thanks.. Work for me.. 100%
          • bekirsalman
            • Nov 2016
            • 137
            • turkey
            thx
            Electronicman
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • vinaypundith
              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
              by vinaypundith
              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
              So, I'm looking for a BIOS dump for this machine - a 16MB one....
              08-03-2024, 12:32 PM
