DUMP BIOS 6050a2566401-mb-a02
  • nacer
    • Feb 2016
    • 130
    • alger
    Need dump
    BIOS HP PROBOOK 650 G1 I3
    N° MAIN 6050a2566401-mb-a02
    N° BIOS WINBOND 25Q128FVSQ
    N° EC MEC1322-NU
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: DUMP BIOS 6050a2566401-mb-a02
    old bios problem what send old bios.
    • nacer
      • Feb 2016
      • 130
      • alger
      He was a regular worker but with a password he wiped the peacock and did not keep the old one
      • nacer
        • Feb 2016
        • 130
        • alger
        Thanks for the interaction
        • nacer
          • Feb 2016
          • 130
          • alger
          And has not been removed from the pios file location works as in the image
          • nacer
            • Feb 2016
            • 130
            • alger
            • imranromi
              • Jan 2015
              • 1292
              • Pakistan
              Can you save file 16mb?before erase.
              • nacer
                • Feb 2016
                • 130
                • alger
                Extract the file in which the solution is resolved
                Thanks for following up
                • nacer
                  • Feb 2016
                  • 130
                  • alger
                  Plllllllzzzzzzz
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
