i need for hp p034nz bios pls pls
  • basic
    • Oct 2017
    • 229
    • 86357289244
    dump bios for hp pavilion p034 nz ..pls to all members
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: i need for hp p034nz bios pls pls
    Do you think anyone is going to respond if you dont provide the complete info like full model number, mobo code etc?????
    • olfelys
      HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
      by olfelys
      Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
      My board enters jumper recovery mode but no BIOS files are available from HP anymore.
      I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
      Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
      post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
      09-05-2025, 12:38 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
