i need for hp p034nz bios pls pls
  • basic
    • Oct 2017
    • 229
    • 86357289244
    dump bios for hp pavilion p034 nz ..pls to all members
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: i need for hp p034nz bios pls pls
    Do you think anyone is going to respond if you dont provide the complete info like full model number, mobo code etc?????
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • MDSI
      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
      by MDSI
      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
      Details:
      Model : HP OMEN 17-an012nf
      Motherboard Part Number : DAG3BAMBAF0 REV : F
      Serial Number (S/N) : 5CD7280D51
      BIOS chip : Winbond W25Q64VSIQ
      Programmer : EZP2023+
      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
      I already...
      Today, 07:11 AM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
