acer e5 551 need bios dump
  • lesterbrazal
    • Aug 2011
    • 38
    good day do you have bios dump of z5wak la -b221p
    thanks a lot more power
  • lesterbrazal
    • Aug 2011
    • 38
    Re: acer e5 551 need bios dump
    i need help pls bios Z5WAK LA B221P
    • imranromi
      • Jan 2015
      • 1290
      • Pakistan
      Send old bios i try build new.
      • maybel
        • Dec 2017
        • 24
        • philippines
        need bios
        • maybel
          • Dec 2017
          • 24
          • philippines
          try this
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            Originally posted by maybel
            try this
            Here if you need bios..
            • balobi
              • Jan 2015
              • 88
              • phillippines
              thanks imranromi it works.
              • mehmet0674
                • Mar 2015
                • 5
                • turkey
                thanks bro
                • reset1986
                  • Dec 2014
                  • 308
                  • italia
                  acer e5-551 la-b222p bios dump
                  the pc turns on with a black screen, ram replaced no result, I am looking for a working bios, I attach my bios
                  mainboard Z5WAK LA-b222P rev 1.0
                  • lapfix
                    • Mar 2020
                    • 2756
                    • my workshop
                    Re: acer e5-551 la-b222p bios dump
                    Your serial or snid
                    • reset1986
                      • Dec 2014
                      • 308
                      • italia
                      Originally posted by lapfix
                      your serial or snid
                      snid 54001502434
                      • lapfix
                        • Mar 2020
                        • 2756
                        • my workshop
                        snid 54001502434
                        try, btw what s your cpu!
                        • reset1986
                          • Dec 2014
                          • 308
                          • italia
                          Amd A10
                          do i try this bios?
                          • lapfix
                            • Mar 2020
                            • 2756
                            • my workshop
                            [QUOTE=reset1986;1170602]Amd A10
                            do i try this bios?[
                            yes and give feedback
                            • reset1986
                              • Dec 2014
                              • 308
                              • italia
                              [QUOTE=lapfix;1170604]
                              Amd A10
                              it does not work, but I found that the chip 216-0844012 gets very hot, I think it is broken
                              • Akwasi
                                • Jun 2018
                                • 21
                                • ghana
                                its working on my A8. Thanks for posting.
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • x14nl34l
                                  Acer TravelMate p614 (tmp614-51-g2-5442) bios dump
                                  by x14nl34l
                                  Hi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
                                  09-01-2025, 09:54 PM
                                • ZOrd_Z
                                  Acer Predator P03-650 bios DUMP.
                                  by ZOrd_Z
                                  I need a bios dump to a Acer Predator P03-650 board.
                                  Or to convert the .CAP file o a file to flash.
                                  Thank's......
                                  10-29-2024, 12:06 PM
                                • haitham sharabati
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  💀 Problem:😅
                                  08-07-2025, 04:54 AM
