Asus U32U bios dump
  • Pascal Komlassan
    • Jan 2017
    • 805
    • TOGO
    Asus U32U bios dump
    Hello please I need the bios dump of this motherboard
  • Pascal Komlassan
    • Jan 2017
    • 805
    • TOGO
    Re: Asus U32U bios dump
    Any helpe ?
    • Pascal Komlassan
      • Jan 2017
      • 805
      • TOGO
      thank you for the help of all everyone. but then I found this by the help of a big brother
      • noname512
        • Oct 2018
        • 41
        • United Kingdom
        laptop power on hard disk but not detecting any sata hard disk and cannot detect any usb to boot from. solved with u32u.rar (1.38 MB, 76 views) now working good. thank you pascal
        • iba
          • May 2018
          • 3
          • indonesia
          thank u32u work
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • kcp0085
            Request BIOS dump for ASUS FA617NS-A16.R77600
            by kcp0085
            Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
            I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
            Specs:
            - ASUS TUF FA617NS-A16
            - CPU: AMD Ryzen 7
            - BIOS chip: Winbond W25Q16JVSIQ (2MB)
            If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
            Thanks in advance!​
            05-02-2025, 12:52 AM
