Hp zbook 15 g2 bios flash
    Re: Hp zbook 15 g2 bios flash
    Hi
    I tried exporting the BIOS with a "Universal BIOS Backup Tool". Not sure if this is the right way of doing it, but if it is:
    Could someone please help me clean out the password from the file?
    I have attached the info about the laptop as well in a jpg
    Best regards
    Jo
      Originally posted by tronsdal View Post
      Hi
      Best regards
      Jo
      have you tried bios from the previous posts? if none works put the original bios here.
        Hi, thanks for replying.
        Yes, I've tried them using Win-key + b when booting, but the caps-lock light is flashing, the screen is black, and nthe fan eventuallyvstarts going really fast, but nothing happens. I uploaded my backed up bios in the previous post (but not sure if it is the right way of doing it with the tool, or if I have to use a chip reader)
          Has anyone had anyluck with this
          I've tried using the posted .bin files several different ways loading onto a USB key via the HP USB Bios updater tool
          Have the same issue as tronsdal
          If I use the M71_130.bin HP provides, the USB bios restore loads and works, but of course doesn't clear the bios password.
          Are these .bin's being posted only working if you flash the bios chip with an external flash programmer?
          HP sucks so hard for bricking their systems with the bios passwords being totally locked out
            Yes, you need an external programmer.
              Can someone remove the password from my Bios?
              It is a ZBook 15 G2
                try...
                  try...
                    Thanks for the answer. I tested them both. The second bios works perfectly. Thanks, saved my day.
                      Hi! Please remove bios password for HP ZBook 15 G2.
                        try...
                          Wonderful!! Thanks!!! It is work. Maybe you knew this password? I lock my home server files with the same password. I forgot it.
                          Very thanks
                            It was password deletion, not decryption.
                            There might be a way to decrypt it but since it's bruteforcing, it might take years
                              5 plinking
                                Hi friends Ihave a zbook 15g2 and wont start up
                                it comes with black screen
                                please can anyone check my bios dump
                                i mthink is a bios problem
                                thanksss
                                  thanksss
                                  the copy of the posted bios is not ok ... make another copy of the laptop bios and post again..post the name and the complete model of the laptop and the motherboard model ..
                                    Hi friends, can someone unlock me this password protected bios from Zbook15G2 25Q128FV?
                                      Have a Zbook 15 G2 with BIOS password set on it. I can log onto Windows and everything but I wanted to clear the BIOS password forever. I managed to read the BIOS without desoldering via RT809H and the files seems to be OK as I explored it using HxD and everything seems intact. Can I just write one of the BIOSes above to check if the password has gone, or somebody need to help me by clearing this BIOS backups password ?
                                        try
                                          Originally posted by Maxpower3 View Post
                                          try
                                          Done, it was fast, thanks you so much.
