Fitc and bios region
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Asus N551JM it start but no video, After I reprogrammed the bios with a dump from vinafix the system start and visualize but after a check with MEinfo there are some errors. So I put the bios region from the vinafix dump into original bios .
    After a restart all is ok so I thinked to download bios from asus main site with the idea to use it instead of bios region from vinafix dump but I noticed that the
    Bios region on decomp directory is 6.144 KB and Bios region (???) from asus site is 6.146 KB , I compare this two files with hexcmp and the last 2 KB contain data, is possible to use this file with its size ?
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Fitc and bios region
    cut away extra data and replace main
    search forum there is thread posted / tutorial by me
    Im Back... sort of...
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      Ok thanks I'll try and searching your thread
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        https://www.badcaps.net/forum/showthread.php?t=60659
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • loopster
          Need help cleaning ME region on Zbook 17 G1 bios dump
          by loopster
          Hello guys,
          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
          Error 10: Failed to open with processed commands.
          Unable to open file: C:\Users\Elitebook...
          06-16-2024, 09:57 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
