Hello please I need the bios dump of this motherboard toshiba satelite L650
toshiba satelite L650 bios dump
Tags: None
Re: toshiba satelite L650
not tested.Attached Filesif you find these attachements useful please consider making a small donation to the site
my friend try this bios:Attached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by DProf.High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
Toshiba Dynabook T55/AB, PT55ABP-BJA2
MODEL NAME. Satellite L50-D series
P[ART NO PS57MN-00600R
Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....-
09-26-2024, 04:30 AM -
- Loading...
