Please i need bios dump for alienware pcb p/n DECH-41-AB3900-A00G PLEASE I BEG YOU ALL
Alienware DECH-41-AB3900-A00G bios
by AhariHi all,
I...-
by TechMark1I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted.
I just zipped it so I could attach it....
Channel: BIOS Requests ONLY!
by druxHi,
I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
These models have AMI/Aptio BIOS.
Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...-
11-03-2024, 01:18 AM -
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
