Acer TravelMate 7720G problems after bios update
  • liladude
    • May 2017
    • Italy
    Hi all, I just joined out of despair after I have managed to make this laptop useless.
    My sister gave it to me few hours before hard disk failure and I barely managed to backup her data. I then bought a new hard disk and installed windows 7 ultimate 32 bit, tried to update bios (with the one from official Acer site under win 7 32bit updates) and failed with the unfamous flash.sys error (tried as admin). I decided to move to windows 7 ultimate 64bit only to discover that firmware 1.22 had an error that prevented the correct use of the 64bit features, so I googled a bit more and found out that the bios flash could only be used under windows xp.
    I searched for the dos rom files, without any success (yes, lot of people talking about getting the zip with both phlasher and win exe in the past, but not a single option for me).
    I decided to try with Hiren's boot cd mini win XP but the bios flash failed with some "power error".
    I shrunk my HD and installed XP into the partition, and finally I successfully installed bios 1.35.
    My happiness was short, since after that I could not boot into windows XP, nor reinstall it, or load a windows 8 cd for accessing the command prompt (as I did for saving the datas while making the backup).
    I just want to fix the mbr for windows 7, or format the hard disk and start installation again, but I cannot understand if the problem is the bios (I can access it and seems to be perfectly working).
    Now I'mgoing to try Hiren's cd again, but I would really appreciate your opinion on the matter.
  • liladude
    • May 2017
    • Italy
    Re: Acer TravelMate 7720G problems after bios update
    Hi all, not sure what happened, but I had to go out after booting into the Hiren's CD and when I come back it booted in XP without problem (well, I have a windows0, so maybe some problems were solved. I fixed the 7 installation with the windows 8 dvd and now I seem able to make a fresh reinstall...
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • akwky
      by akwky
      Hi!
      04-14-2025, 01:56 PM
    • al3m0di
      Update bios EFCN58WW to EFCN59WW
      by al3m0di
      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
      The BIOS version is EFCN58WW.
      When I turn on the device, it displays the message:
      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
      I've tried
      07-29-2024, 10:32 AM
    • Caimano
      Problems extracting from Dell Bios Update.Inspiron 3793
      by Caimano
      I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
      The board is FDI45-LAJ091P REV 1.0 A00
      Processor i7 1065G7 with GPU
      This MB has 2 Bios Chips (one 8MB and one 16MB chip).
      I am trying to reload a new Bios with clean ME region, new main region and new EC region.
      I attach the dumps of the 2 chips.
      I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
      05-04-2022, 11:19 AM
