Np915s3g-k02 samsung
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Hi
    This laptop doesnot boot from hdd nor from usb
    I tried to disable secure boot and fast boot
    It sees only the usb but cannot boot from it
    Even in csm mode
    Any suggestions?
    If the problem is with bios have any one the dump file?
    Thnx
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Re: Np915s3g-k02 samsung
    Is there any bios file?
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
      09-07-2024, 05:50 AM
    • eigma
      Samsung UN40H5003 boot loop every ~8 seconds
      by eigma
      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
      Main board: BN94-07592P / BN97-08922R...
      11-20-2024, 10:31 PM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
      09-06-2024, 11:40 PM
