Ripped Solder Pad, Bios chip, Macbook Motherboard.
  • KennyChan
    • Apr 2017
    • 5
    As the title says, I accidentally ripped off the 8th Bios pin solder pad for a Mid-2012 15” Macbook pro. As I did research on how to fix this, i went to scraping at the center of the broken pad. at first i tried to resolder it back so i can make a connection. that failed since the solder didn't stick. so i scraped again. upon the second attempt i accidentally scrapped the middle, completely fraying the copper wire, so i worked my way outwards to expose the outer parts within the broken pad. my next move is to get wire glue to reconnect the circuit and replenish the pad so i can install my new bios chip. BUT, something is holding me back..
    I used a multimeter and tested continuity on each side of the broken pads copper exposed wire,
    (one connected to ground)
    left side of broken pad i have resistance
    right side of broken pad i have no resistance - as if this is another ground (beeping and reading 0)
    from my research the 8th pin is the vcc power supply for the bios chip. I am stuck and don't know if i should go ahead and “wire glue the pad” with the left and right making a circuit. Im afraid it might short.
    the laptop motherboard model is 820-3330-B
    any thoughts?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Ripped Solder Pad, Bios chip, Macbook Motherboard.
    No I think you would better isolate the part of the board you scrapped, and run a jumper wire between the VCC pin and another point connected to the power line from the board. Check which other component/pad is connected to this line using a boardview. Also check for a short between this power line and ground, to make sure you didn't create a short while scraping the board.
    • diif
      • Feb 2014
      • 6978
      • England
      Don't scratch at the board. Use the boardview/schematic to find out what the missing pad goes to. It might be to late now from your description.
      • KennyChan
        • Apr 2017
        • 5
        @piernov, I was thinking the same thing also. But not sure how to locate a power line. i tested both sides at once and it same results as the left side.
        @diif, I have learned a valuable lesson the hard way. I might just scrap this board.
        • KennyChan
          • Apr 2017
          • 5
          When i try to power it on, light comes on for a second and just shuts right off. Not sure if its cause Bios chip isnt getting power or theres a short.
          • piernov
            • Jan 2016
            • 4439
            • France
            Locate the BIOS chip on the boardview (you can open it using OpenBoardView), click on the pin you're interested in and it will highlight the other parts' pin connected to the same line. Then check for a short to ground on one of those pins. If it's ok, solder a jumper wire between this pin and your BIOS pin.
            • KennyChan
              • Apr 2017
              • 5
              @piernov, does it matter if the lines are red or blue? That seems to confuse me.
              • piernov
                • Jan 2016
                • 4439
                • France
                Red points to pads on the same side of the board, blue points to pads on the other side of the board. You want a pad on the same side, pointed by a red line.
                • highpulse
                  i hate HP
                  • May 2013
                  • 1490
                  • portugal
                  kenny chan , this issue your having sounds bad bios chip , if its the flat soic chip , you need to replace it and reprogram it , and under the ripped pad , simple add bit of kapton to avoid bios to touch the board on that pin , solder a wire on that vcc pin , if you want tell me board code and i send you picture were you need to jumper a wire
                  but first try reflashing bios and see if its still read /wwrite .
                  • maq2130
                    • Jul 2017
                    do you happen to have a bios dump for that board?
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • mrfomt
                      Bios broken solder pad Elitebook 840 G2
                      by mrfomt
                      Hello.
                      Have a HP Elitebook 840 G2, should swap the bios so I desoldered the main bios chip U365. The solder pad on pin 5 broke. si/sio0. Can't find the chip in the schematics. Maybe I could solder a wire from pin 5, but don't know where the other end of the wire should go.
                      11-05-2023, 11:04 AM
